Wiring / Component newbie question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-05-2013, 05:09 AM - Thread Starter
RevRab's Avatar
Hello all -
I've looked around for ever and can't seem to find exactly what I'm looking for, I'm hoping someone here can help.
I am planning on buying a new stereo system. It will be the first system I'll own that I need to use an amp separate from just a receiver.
As of now I'm looking at getting Cerwin-Vega XLS 215 (2) and Criwn XLS2500
My primary use for this will be to listen to music and maybe someday buying more components to create a theater system.
So my ignorance comes from not knowing how to sequence these devices so that I can still have multiple sources (iPod, PC, Turn Table exc.). My current setup just consists of speakers hooked directly into the receiver wire terminals. How do I wire the Crown in?
Sorry if it's a dumb questions but your help is appreciated.
Robert
RevRab is offline
post #2 of 5 Old 09-05-2013, 07:35 AM - Thread Starter
RevRab's Avatar
I guess I will use a DJ mixer and that should work fine. I still just don't understand what people do for home theater though.
RevRab is offline
post #3 of 5 Old 09-05-2013, 07:49 AM
eljaycanuck's Avatar
Quoted: 1264 Post(s)
Liked: 1857
If you want to use an external amp in an HT set-up, the usual way to go about it is to buy an A/V receiver (AVR) with multi-channel analogue pre-outputs and then connect:
- all your components to your AVR;
- the AVR to the amp via the AVR's pre-outputs;
- the amp to the speakers using speaker wire.
eljaycanuck is offline
post #4 of 5 Old 09-05-2013, 07:55 AM
Ross Ridge's Avatar
Liked: 81
For home theatres people either get an AV receiver or much more rarely, an AV pre-amplifer and a multi-channel power amp (or set of power amps).
The Crown XLS2500 Power Amplifier you're considering is a PA amp and isn't meant for home use or with the speakers you mentioned. If you really want to use it anyways, you can use it with a stereo pre-amplifer or a AV pre-amplier (also called AV pre-processors). The later would give you video switching and the ability to create a surround sound home theatre system with more speakers and power amplifers.
Ross Ridge is offline
post #5 of 5 Old 09-05-2013, 08:08 AM - Thread Starter
RevRab's Avatar
Thanks for the responses. What is the difference between a PA amp and a stereo amp?
For strictly stereo I was thinking I could run the components into a mixer like this Behringer VMX1000USB
MIXER ----> Power AMP ----> Speakers
RevRab is offline
