8 ohm to 6 ohm - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-05-2013, 10:40 AM - Thread Starter
cubbear's Avatar
I can't seem to get receiver to change speaker setting from 8 ohm to 6 ohm to match my speakers. tried what manual says does not seem to work
cubbear is offline
post #2 of 9 Old 09-05-2013, 10:49 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1798
What's the make and model of your AVR? Of your speakers?
-- Edit --
Never mind, I see from another thread you started that you have a Pioneer VSX-1019. The instructions on pg. 36 of the owner's manual seem pretty straightforward:
Switching the speaker impedance
1 Switch the receiver into standby.
2 While holding down ENTER on the front panel, press  STANDBY/ON.
The display shows RESET ◄ NO ►.
Use TUNE +/– (or ↑ / ↓ on the remote control) to select SPEAKER ◄ 8Ω ►, and then use PRESET +/– (or ← / → on the remote control) to select SPEAKER 8Ω or SPEAKER 6Ω.
• SPEAKER 8Ω – Use this setting if your speakers are rated at 8 Ω or more.
• SPEAKER 6Ω – Use this setting if your speakers are rated at 6 Ω.
eljaycanuck is offline
post #3 of 9 Old 09-05-2013, 10:58 AM - Thread Starter
cubbear's Avatar
pioneer VSX-1019 AH-k and pioneerd sp-bs22-lr
cubbear is offline
post #4 of 9 Old 09-05-2013, 11:01 AM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Leave it @ 8 Ohms..
It wil put out more power and have better dynamics...
Just my $0.02... 👍😉
M Code is online now
post #5 of 9 Old 09-05-2013, 11:18 AM - Thread Starter
cubbear's Avatar
tried above could not get it to switch
cubbear is offline
post #6 of 9 Old 09-05-2013, 11:23 AM
Liked: 1798
Weird. Wish I could help, but it seems so straightforward I can't think of anything to suggest.
post #7 of 9 Old 09-05-2013, 12:57 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Just leave it on 8 ohms. In my main room I have a mix of 8 ohm energy towers and 6 ohm Jamo towers. All powered by my Denon receiver. Never had any problem and the receiver does not have a switch.
I have owned 5 different receivers from Denon, Harman Kardon and Marantz over the past few years and none of them had a 6/8 ohm switch. Why is this even necessary?
Is the power supply that bad in the Pioneer 1019 that one needs to change the setting?
Afro GT
afrogt is offline
post #8 of 9 Old 09-05-2013, 01:27 PM - Thread Starter
cubbear's Avatar
thanks a lot I was worried it would cause a problem Cheers Rob
cubbear is offline
post #9 of 9 Old 09-05-2013, 03:58 PM
MMickk's Avatar
MMickk is offline
