Server Error - AVS Forum
post #1 of 5 Old 09-07-2013, 08:04 AM - Thread Starter
Discflite's Avatar
Ongoing issue with Denon 2112CI when trying to run Pandora, worked perfect for several months, but now I get a "SERVER ERROR" and will not connect, it looks like it wants to connect, goes as far as lauching the title then gets hung up with an error message; SERVER ERROR? tried setting the ip address with no luck.....anybody know how to troubleshoot?
Discflite is offline
post #2 of 5 Old 09-07-2013, 08:10 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 266 Post(s)
Liked: 1300
Have you tried resetting the router? Or perhaps set a static IP per the Owner's manual?
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun, leave message)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #3 of 5 Old 09-07-2013, 08:36 AM - Thread Starter
Discflite's Avatar
By luck, Uverse just replaced my router two days ago, not sure about setting the static ip address, if you mean matching it up in the menu option I did attempt, not sure I did it right.....sorry not a very technical person.
post #4 of 5 Old 09-07-2013, 09:53 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 266 Post(s)
Liked: 1300
If the router was changed out, it most likely now has a different access code. Is the AVR wired directly into the router? Do other components have access to the internet when connected to the router?
post #5 of 5 Old 09-07-2013, 10:40 AM - Thread Starter
Discflite's Avatar
No, unfortunately the ATT router is upstairs and is our main wireless source, it feeds into a net gear box and where I have a Plug Link wired in. My receiver is downstairs hooked up to the plug link adapter.
I searched the ip address through my iphone and laptop trying to manually set the ip address on the Denon.
User Tag List
