TV Audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-07-2013, 02:37 PM - Thread Starter
gtispeed's Avatar
I have a Panasonic smart tv hooked up through the Marantz system. Everything is run through the Marantz and to the TV working perfectly. The only problem is - when running the smart tv, I need the audio sent from the TV to the receiver. I have plugged in the digital audio out into the TV in digital audio - set the Zone 1 to TV in but no luck. The only sound is through the TV speakers. I'm sure it's just a setting I have wrong but can't figure out what setting to change! Any help would be appreciated!
gtispeed is offline
post #2 of 5 Old 09-07-2013, 04:18 PM
oztech's Avatar
Liked: 101
Have you tried turning the TV speakers to off ?
oztech is offline
post #3 of 5 Old 09-07-2013, 04:45 PM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 972
That's not going to get your sound to the receiver. You need to go from the optical out on the TV to one of the optical inputs on Marantz. Then you need to check your Marantz setup to see which input the optical is assigned to.
It would also help if you told us which Marantz receiver you have.
Afro GT
afrogt is offline
post #4 of 5 Old 09-07-2013, 05:06 PM - Thread Starter
gtispeed's Avatar
I have turned the speakers off but that didn't help. Sorry it's the SR6007. I have it plugged into the digital audio in fot tv.
gtispeed is offline
post #5 of 5 Old 09-07-2013, 08:32 PM - Thread Starter
gtispeed's Avatar
I figured it out! I needed to go back and tell the receiver that I had connected the TV into it. All good now!
gtispeed is offline
