Help - Aventage RX-A2010 On Screen Display Issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-09-2013, 01:55 PM - Thread Starter
YamahaChris's Avatar
Hi new around here but long time follower...hopefully this is the correct forum.
I'm having an issue with my on screen display and its happened twice now since purchasing the unit last September 2012. The graphic interface will appear but most of the words are corrupt or missing characters. The only remedy I have found so far is to reset the unit to factory defaults which kills all my settings. Firmware is the latest version (1.37) and it has seem to happen on that version and the previous. I believe I have updated it twice since owning it. Has anyone encountered this and have a fix or maybe an easier way to reset version a complete wipe?
Thanks for any help!
Chris
YamahaChris is offline
post #2 of 2 Old 09-09-2013, 10:51 PM
braveheart123's Avatar
Quoted: 330 Post(s)
Liked: 287
Try a different HDMI cable.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
Yamaha Rx A2010 Receiver
