Replacement for failing Yamaha RX-V2700? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 09-11-2013, 10:27 AM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
A friend gave me this receiver as a hand-me-down. It's awesome but when things get too loud, it cuts off and gives me the "Check SP wires" message when I turn it back on. Also, two of the three HDMI inputs don't work and the other one seems to be getting more erratic. So, I need to start thinking about replacing it.
What would give me comparable performance while hopefully not costing too much? I use it entirely for home theater. I assume everything has YPAO or equivalent these days?
Using it with 3 Canton Karat KM4 front speakers, a Klipsch RW12d sub, and some random rear surrounds from a HTIB.
curttard is offline
post #2 of 13 Old 09-11-2013, 10:33 AM
eljaycanuck's Avatar
Quoted: 1227 Post(s)
Liked: 1799
All receivers have some form of room correction / auto EQ:
- YPAO (Yamaha)
- MCACC (Pioneer)
- Audyssey MultEQ, MultEQ XT, MultEQ XT32 (Denon, Marantz, Onkyo)
- et cetera
How much is "not costing too much"? And what features are a must within that price cap?
eljaycanuck is offline
post #3 of 13 Old 09-11-2013, 10:48 AM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Honestly in terms of features I doubt I want anything that every receiver won't have. A couple HDMI inputs. A couple HDMI outputs would be great but honestly I don't really need the outputs.
Price target would hopefully be $500 or less. Has tech improved enough where I could get something comparable or superior to the V2700 in that price range these days?
curttard is offline
post #4 of 13 Old 09-11-2013, 10:55 AM
Liked: 1799
$335 @ Amazon.com will get you a Denon AVR-1713:
- 5.1 channels
- 6 HDMI inputs (5 in back, 1 in front)
- 3D pass-through
- Audyssey MultEQ XT
It's an out-going model, but it's well-equipped and fairly well-rated.
post #5 of 13 Old 09-11-2013, 11:03 AM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Thanks. That's what I was hoping to hear. Do you have any idea how sound quality might compare? The Yamaha was around $1200-1500 back in the day, has tech trickled down such that today's $350 receiver does as good a job?
curttard is offline
post #6 of 13 Old 09-11-2013, 11:34 AM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
The Yamaha's 2700 amplifiers are significantly better than those in the Denon 1713. I would suggest you raise the $ to get closer....
Check out the Yamaha Aventage RX-A730 or 830..
Just my $0.05.... 👍😉
M Code is online now
post #7 of 13 Old 09-11-2013, 12:07 PM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Hmm, at $650 for that maybe I'd be better off getting my 2700 fixed?
curttard is offline
post #8 of 13 Old 09-11-2013, 04:18 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Check around for better Yamaha pricing..
Also keep in mind, the bench rate repair bill will be @ least $200..
post #9 of 13 Old 09-11-2013, 04:24 PM
Home Theater Lover
Craig Peer's Avatar
Quoted: 3038 Post(s)
Liked: 2969
Current home theater photos - http://www.avsforum.com/photopost/sh...hp?cat=2386514
craigpeer@earthlink.net
Craig Peer is offline
post #10 of 13 Old 09-11-2013, 05:48 PM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Best Yamaha price I've seen was $430 for clearance Aventage RX-A820BL.
In terms of sound quality, what other modern AVRs compare to the RX-V2700, so I can keep my eyes open for deals? I'm not at all sure I would notice a difference between it and lower end models, but at the same time I'd obviously rather not go backwards in quality and risk hearing a difference.
curttard is offline
post #11 of 13 Old 09-13-2013, 11:39 AM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Which Denon or Marantz models are comparable in terms of sound quality?
curttard is offline
post #12 of 13 Old 09-21-2013, 12:52 AM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
How about an open box Aventage 820 for $360? Also open box 720 for $250.
curttard is offline
post #13 of 13 Old 09-21-2013, 12:09 PM - Thread Starter
curttard's Avatar
Quoted: 111 Post(s)
Liked: 31
Now I'm reading good things about Denons, especially their Dynamic EQ. What Denon models would be comparable in sound quality to the RX-V2700?
The 8in-2out hdmi of the Yamaha 820 is appealing too though -- then I could retire my Monoprice HDMI switcher.
curttard is offline
Denon Avr 1713 Receiver , Yamaha Rx A730 7 2 Channel Network Aventage Home Theater Receiver , Yamaha Rx A830 7 2 Channel Network Aventage Home Theater Receiver , Yamaha Rx A820 7 2 Channel Network Aventage Av Receiver
