I'm trying to set up two speakers that have quarter in into raw cable, into my Denon AVR-391 without the remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-11-2013, 04:07 PM - Thread Starter
Aaron Bouchard's Avatar
I have two Peavey speakers that i would like to connect to my receiver. I connected the speakers to the receiver, and tried using an aux cord but haven't had any luck. also I don't have a remote so I'm not sure if or how I can set this up.
Aaron Bouchard is offline
post #2 of 2 Old 09-11-2013, 07:56 PM
JHAz's Avatar
Quoted: 306 Post(s)
Liked: 271
you have to plug them into an amp on the receiver. line level outputs won't cause the speakers to make any noise . . .
you can strip the wires and connect the 'raw cable' to the appropriate amplifiers on the Denon.
you might find it easier, assuming the Denon's terminal spacing is right, to pick up quarter inch to banana plug speaker cables and just plug them in. My sense is this is likely your best bet. Guitar Center or similar will have a range of such cables. Don't splurge. You're not going to be winding and unwinding these cables multiple times per week, so they needn't be the most, uh, robust construction in the world.
JHAz is offline
