Onkyo receiver with HDMI problems - AVS Forum | Home Theater Discussions And Reviews
Old 09-13-2013, 06:38 AM - Thread Starter
elsaddiq's Avatar
I have an old Onkyo TR SX606 receiver that has HDMI issues. Do I lose anything other than the ability to do video switching by connecting my dvd player directly to the tv's HDMI and using the tv's coaxial audio out for sound? Is there a downside to this? Thanks.
elsaddiq is offline
Old 09-13-2013, 07:21 AM
jdsmoothie's Avatar
Quoted: 12097 Post(s)
Liked: 5507
Depending on the TV, the audio from the "optical" audio out could be either PCM 2.0 or DD 5.1 (providing the DVD is set to pass DD 5.1 of course). A better option is to connect an optical/coax digital cable from the DVD player to the AVR which should ensure the DD 5.1 passes.
jdsmoothie is offline
Old 09-13-2013, 08:08 AM - Thread Starter
elsaddiq's Avatar
I have the Insignia NS-39L240A13 which does pass 5.1. If there is no known issues with connecting to the tv, I'd rather do this than run separate connections for each device (gaming, netflix pc, dvd, etc.) If you guys see a negative to this, please chime in. I'd hate to have to buy another receiver now.
elsaddiq is offline
Old 09-13-2013, 08:47 AM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
The only downside is there are some codecs that won't work via toslink, but you probably wouldn't notice much difference between them and regular 5.1.
KidHorn is offline
Old 09-13-2013, 08:57 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Are you SURE it passes 5.1 from other sources?
Afro GT
afrogt is offline
Old 09-13-2013, 11:33 AM - Thread Starter
elsaddiq's Avatar
With Insignia it appears that any audio carried over HDMI will be passed through the digital outs.
elsaddiq is offline
Old 09-13-2013, 11:45 AM
afrogt's Avatar
Liked: 755
Yes, but that doesn't mean is will not be converted to 2.0 PCM like most TV's do.
Afro GT
afrogt is offline
