HOW TO CONNECT THE ONKY TX-NR809 TO MY SPEAKERS AND TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-13-2013, 11:59 PM - Thread Starter
jertje's Avatar
Hello
A few monds ago i bougt a Onky TX-NR809, a Onkyo BD-SP309 Blu-Ray player (Black) and a speaker set. this is the link of the speaker set: http://www.megakeuze.nl/Luidsprekers/Pure-Acoustics/pure-acoustics-supernova-5
2 people came install it, but i think they dit it rong. can somane help me how to connect the speakers, blu-ray player and the tv to the receiver.
already thanks
jertje is offline
post #2 of 4 Old 09-14-2013, 03:40 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
The most basic and common way of connecting your gear would be as follows:
1) Connect the blu-ray player via HDMI cable to HDMI input labled blu-ray on the back of the 809.
2) Connect the 809 main HDMI output to any HDMI input on your TV
3) Connect you main left and right speakers to the the left and right speaker binding post on the back of the onkyo using 12 or 14 awg speaker wire.
4) Connect the center channel speaker to the center channel binding post on the back of the onkyo using 12 or 14 awg speaker wire.
5) Connect the surround channels to the L and R surround channel (note surround channel, not rear surround, which is only used in a 7.1 or more set up) binding post on the back of the onkyo using 12 or 14 awg speaker wire.
6) Using a coax audio cable connect the sub preout on the back of the onkyo to the LFE input on your subwoofer.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #3 of 4 Old 09-14-2013, 07:58 AM - Thread Starter
jertje's Avatar
thanks for your help. the speakers and the subwoofer are connected properly, but i cant find a hdmi input labeld blu-ray.
which one is it???
jertje is offline
post #4 of 4 Old 09-14-2013, 10:22 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
HDMI input #1 labled BD/DVD. BD is short for bluray disc. Also so you know it doesn't really matter what hdmi input you use as they are are configurable in the onkyo set up menu. The bd/DVD input defaults to the same button on the remote so it is easier just to use the default input.
67jason is offline
Onkyo Tx Nr809
