Can I Bi-Amp AND use Zone 2 with Denon 4311 using external amp(s). - AVS Forum | Home Theater Discussions And Reviews
Old 09-14-2013, 03:16 AM - Thread Starter
StevenLyall's Avatar
Hi - I know that I lost the ability to Bi-Amp my main front speakers when I started using Zone 2 with my Demon 4311.
Is there a way to Bi-Amp AND use Zone 2 if I add an external amplifier and 'feed' it from available pre-amps in the 4311?
Advice much appreciated.
StevenLyall is offline
Old 09-14-2013, 06:07 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Yup. Just connect the external amp to the Zone 2 pre-outs, although note that there is likely to be no real gain using the "bi-amp" connection so you may want to try that first before purchasing an external amp.
jdsmoothie is offline
Old 10-19-2014, 06:20 AM - Thread Starter
Hi - just to say that I did attach an external amp to teh Zone 2 pre-outs and all is well. However, I've noticed something that may or may not have been true before, but I'm curious.
I notice that a single input feeds Zone 1 and 2 sound for my Logitech Squeezebox (Opt) and my Sky TV box (HDMI), while I need separate digital inputs for my Apple TV to get sound in both zones.
I'm just interested to know why these are different.
Steven
Old 10-19-2014, 06:31 AM
jdsmoothie's Avatar
Liked: 5508
HDMI will not pass to Zone 2, while PCM 2.0 optical/digital coax and analog will.
Old 10-19-2014, 07:03 AM - Thread Starter
Many thanks - I think I described my equipment's behaviour inaccurately, but what you have just explained is perfect.
Old 10-19-2014, 07:23 AM - Thread Starter
Actually, the only problem I have since beginning to use the pre-amp Zone-2 output through an external Amp for Zone 2 is Apple TV. I find that Apple TV music plays perfectly in Zones 1 & 2, but when I try to play a movie, it's just a crackling sound in Zone 2. This wasn't a problem before.
Old 10-19-2014, 07:25 AM
jdsmoothie's Avatar
Liked: 5508
The AppleTV 5.1 audio must be down mixed to PCM 2.0 first.
Old 10-19-2014, 08:31 AM - Thread Starter
Yes - apologies for not providing details. What I had working before was to use Apple TV's HDMI for Zone 1 sound and video, and Apple TV's Optical output through a Digital-to-Analogue converter to a par of CoAx inputs. Had it working for a year or more and I must have changed something when I started using teh external amp for Zone 2. Not sure what, yet.
Thanks again.....
Old 10-19-2014, 10:22 AM
jdsmoothie's Avatar
Liked: 5508
Have you confirmed audio is actually passing through the digital --> analog converter by selecting that input in the main zone?
Old 10-20-2014, 01:55 PM - Thread Starter
Yes, thanks, I did that and I get the same result. Playing a music file (iTunes) is perfect, but a purchased move just crackles. But I think that it's just a fault in the Apple TV - I swapped it for anothyer one, and all is well.
Many thanks for your help.
Steven
Old 10-20-2014, 06:20 PM - Thread Starter
And, for the sake of completeness, neither of my Apple TVs were actually faulty. In rebuilding by system, I had swapped my 2 Apple TVs and the one that went to the Denon with 2 zones did not have Dolby Digital set to Off, which causes teh problem with the signal going through the Digital-to-Analogue converter.
I had solved this 'problem of understanding' a year or so ago, but had forgotten.
Many thanks again.....
Old 10-20-2014, 06:34 PM
jdsmoothie's Avatar
Liked: 5508
Sure. Thanks for reporting back as it will help others as well.
Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a
