Onkyo NR515 keeps resetting subwoofer and central levels to some preset - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-14-2013, 03:43 PM - Thread Starter
Vova Vladimir's Avatar
It does it every few days, so I have to go to quick setup > audio and change them back to 0's every time. Any idea why it's doing it? I suppose it could be Audissey?
Vova Vladimir is offline
post #2 of 4 Old 09-14-2013, 05:19 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4780
The quick setup changes aren't kept on my Onkyo once you power off. Not clear why you are changing them to "zero", why are you doing that? Did you do a full setup with Audyssey and don't like the sub and center settings?
lovinthehd is offline
post #3 of 4 Old 10-14-2013, 06:58 PM
David Limbac's Avatar
Ya, I suppose they were set by Audessey. Can I change those settings to something else and keep them that way?
David Limbac is offline
post #4 of 4 Old 10-14-2013, 08:00 PM
lovinthehd's Avatar
Liked: 4780
Sure you can change them from what Audyssey and your avr do during auto setup; keep in mind they weren't set to zero by the auto setup for no reason....
Do you prefer just doing it by ear or are you using an spl meter and tape measure? Just use the main menu instead of the quick setup. I think what my manual (for a different Onkyo model) says, as long as you go to the main menu while the changed settings are in place they'll keep them but you should double check.
Onkyo Tx Nr515
