AVR-2808ci Sound issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-15-2013, 11:37 AM - Thread Starter
toddcordes's Avatar
Recently my 2808ci started experiencing sound issues on some TV channels. It does not want to play the voice track. For example, with today's football game I can hear all the stadium sounds but not the announcers. On a different channel we can hear sound effects and the laugh tracks but not the dialogue. I have confirmed on other TVs that the channels are broadcasting normally. It does not effect all channels. I have done the reset per pg 50 twice. Thoughts?
toddcordes is offline
post #2 of 6 Old 09-15-2013, 12:04 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
what happens if you switch to other "processing" options? I have notice similar issues on some sports channel on satellite on my 4308. My guess is I may have to switch a few things off like audyssey stuff and such.... or may be rerun things. Perhaps the specific channels aren't mixing their sound quite "right" and the unit is having some issue with dealing with particular sound placement.
budwich is offline
post #3 of 6 Old 09-15-2013, 12:19 PM
afrogt's Avatar
Quoted: 1022 Post(s)
Liked: 747
Are you sure the center channel didn't get turned off? That's where the main voices will come from. Check speaker wires too.
What sound mode are you using when you watch TV?
toddcordes likes this.
Afro GT
afrogt is offline
post #4 of 6 Old 09-15-2013, 02:20 PM
jdsmoothie's Avatar
Quoted: 11872 Post(s)
Liked: 5419
Try swapping the center speaker with either FL or FR speaker to check whether it's a center channel or center speaker issue.
jdsmoothie is online now
post #5 of 6 Old 09-15-2013, 11:14 PM
BAMAVADER's Avatar
Quoted: 17 Post(s)
Make sure that the receiver hasn't been switched to the B speakers instead of A...this happened to me one time with similar results...
RTR
BAMAVADER is offline
post #6 of 6 Old 09-24-2013, 07:43 PM - Thread Starter
toddcordes's Avatar
Thanks for turning me onto the center speaker. That was the issue.
Denon Avr 2808ci Receiver
