Sound dips out for a second or two every time something else in the house is switched on... - AVS Forum | Home Theater Discussions And Reviews
Old 09-15-2013, 01:51 PM - Thread Starter
tim3057's Avatar
Our Denon AVR-1912 amp / receiver works fine except when the freezer clicks on, then the sound drops out to nothing for about a second, then returns. Happens every time the freezer thermostat clicks on. We've unplugged the power line network, and everything else, it's just the amp. Same happens whatever is going through the denon, be it TV, airplay or movies from remote Mac. No indication of any kind on the amp, no warning lights, no messages, just a short dip in sound output. Any help much appreciated!!smile.gif
tim3057 is offline
Old 09-15-2013, 02:12 PM
jdsmoothie's Avatar
Quoted: 12172 Post(s)
Liked: 5547
Perhaps try connecting to a different outlet that is on a different circuit.
jdsmoothie is offline
Old 09-15-2013, 03:44 PM - Thread Starter
tim3057's Avatar
Good idea, except that the AVR needs to be next to the TV, and is on a mains spur that is the only one in the room..
and the freezer is two rooms away on a different circuit already..
tim3057 is offline
Old 09-15-2013, 08:52 PM
Trendy's Avatar
Your AVR and the freezer are likely on the same phase in the circuit breaker box. Try moving the one or the other to the other phase. Naturally you will want to shut off the main breaker before doing this, or call an electrician.
Trendy is offline
Old 09-16-2013, 12:42 AM - Thread Starter
tim3057's Avatar
Good idea, but in the UK we are on a single phase 240v supply, so there is no option to shift to another phase. Something in the freezer switching - and actually sometimes in the fridge, which has the same effect - spikes the circuit. I would guess this is common, but only the Denon (not the TV nor any other appliance) reacts in this way. Is there a device that can smooth out the supply?
tim3057 is offline
Old 09-16-2013, 07:53 PM
Trendy's Avatar
Don't personally have any experience with your electrical supply. However, I suspect that your problem is a drop in voltage when the freezer hicks in. This would be different from a spike in the voltage – which most power line filters would tackle. Try a Google for voltage sage. Wiser individuals on the forum may have ideas for how they handled HVAC problems.
Trendy is offline
Old 09-16-2013, 09:14 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 423
Is this an older house?
If yes, sounds like too much current on 1 circuit..
Just my $.0.05... 👍😉
M Code is offline
