MONEY BETTER SPENT ON LOW END 7.1 RECIVER OR BUY USED? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-17-2013, 06:24 PM - Thread Starter
saint1000's Avatar
i have around 400 to spend on a 7.1 receiver. would i be better off going with a new low end reciver like a pioneer vsx-1122-k or go with a higher end used on like a onkyo TX SR805 or marantz sr7001. i am running a htpc setup and want to upgrade my 15 year old denon to a 7.1 setup. thanks for any replies
saint1000 is offline
post #2 of 6 Old 09-17-2013, 06:51 PM
Occam's Chainsaw's Avatar
You'll get more bang for your buck buying used. I have a Marantz SR 7001 and it's a great receiver. It has everything you'll need for an awesome home theater. It doesn't have all the bells and whistles that the new receivers have, but it sounds great and will be able to switch all of your components.
jrhooper1963 likes this.
"Paradise is exactly like where you are right now... only much, much better." - Laurie Anderson
Occam's Chainsaw is offline
post #3 of 6 Old 09-17-2013, 06:59 PM
jdsmoothie's Avatar
Quoted: 15384 Post(s)
Liked: 7527
Depends on what features you want as those older models may not have some of the features of the more current models. Review their respective mfr websites and determine which best meets your needs.
spddy101 likes this.
jdsmoothie is offline
post #4 of 6 Old 09-18-2013, 07:15 AM
jrhooper1963's Avatar
Quoted: 99 Post(s)
Liked: 38
Stay away from Onkyo. The HDMI boards in them, have a terrible track record.
KidHorn and spddy101 like this.
jrhooper1963 is offline
post #5 of 6 Old 09-18-2013, 09:29 AM
KidHorn's Avatar
Quoted: 1492 Post(s)
Liked: 982
I would get a new one with a new warranty. Why take a risk when you don't have to.
Basically all receivers are the same. Some have some high end features like Audyssey xt32 or can do more than 7 channels, but for general use, they're all more or less the same. Buy for reliability and if there's must have feature. Don't buy for perceived quality differences.
KidHorn is offline
post #6 of 6 Old 09-18-2013, 12:18 PM
Anthony1's Avatar
Quoted: 604 Post(s)
Liked: 369
They are all the same?
So, a receiver that was selling for $2499.99 four years ago, has the same quality as a $400 cheapo unit today? I seriously doubt that.
Anthony1 is offline
Pioneer Vsx 1122 K , Onkyo Tx Sr805 7 1 Channel Home Theater Receiver Silver , Marantz
