"Official" Emotiva UMC-200 Thread - Page 14 - AVS Forum
post #391 of 413 Old 07-11-2014, 08:10 AM
hifiaudio2's Avatar
Quoted: 48 Post(s)
Liked: 59
Here is a link to my first REW measurement. Its not what you asked for because I have spent the entire time so far with the UMC chasing down a ground loop. Having to order a fiber optic HDMI cable to beat it. But that is another story.
Here is the link. Its the center channel along with the sub, and one filter applied in the Xilica. 45 hz -8.25db .21oct q=6.863
Noise floor in room is read to be around 42dB because the UMM6 mic is known to not measure the noise floor any lower.
https://www.dropbox.com/s/eefb703ios...021_08_25.mdat
hifiaudio2 is offline
post #392 of 413 Old 07-11-2014, 08:26 AM - Thread Starter
markus767's Avatar
Quoted: 302 Post(s)
Liked: 171
Thanks. Looks pretty good. Strong reflection after 2ms (floor/ceiling?). Bass array needs better time-alignment.
What does the sub array look like without the filter and center? Set crossover to 250Hz for the measurement.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #393 of 413 Old 07-11-2014, 08:38 AM
hifiaudio2's Avatar
Quoted: 48 Post(s)
Liked: 59
I wonder if that reflection is the false screen wall or the soffit.
I was thinking that above 200hz the graph looked pretty bad. Is that normal behavior? Your 1/48 smoothed graph above looks extremely different.
post #394 of 413 Old 07-11-2014, 08:50 AM - Thread Starter
markus767's Avatar
Quoted: 302 Post(s)
Liked: 171
The reflection might be the chair. Must be something very close to the speaker and/or the mic.
Response doesn't look bad, it's normal behavior. What you see is room modes and reflections.
Markus
post #395 of 413 Old 07-11-2014, 08:42 PM
hifiaudio2's Avatar
Quoted: 48 Post(s)
Liked: 59
Lol I am running tests now.. I forgot the LFE channel runs 10db hot so I got a nice surprise of 99dB at 12.9hz. Found a can light rattle (just loose).
My link above should have the new set of files now.
All of the new tests are with the UMC-200 now.
post #396 of 413 Old 07-12-2014, 01:30 AM - Thread Starter
markus767's Avatar
Quoted: 302 Post(s)
Liked: 171
13Hz seems to be your first room mode. It's visible in your measurement. How large is the whole structure around your HT?
Markus
post #397 of 413 Old 07-12-2014, 05:34 AM
hifiaudio2's Avatar
Quoted: 48 Post(s)
Liked: 59
The theater is at the end of the basement. But the rest of the basement is another 1500 sq ft or so. The room is normally sealed but the door had to be cracked for the HDMI cable to reach outside the room to my equipment rack.
post #398 of 413 Old 07-13-2014, 03:44 PM - Thread Starter
markus767's Avatar
Quoted: 302 Post(s)
Liked: 171
Just heard back from John (REW author). He says that REW "seems to struggle with the XP2040's freq and gain steps". He suggests "using the Generic setting for the match then changing the setting to XP2040 when it is done".
So everyone with a XP2040 check your settings if REW delivers low Q settings at subwoofer frequencies. Normally REW uses the unsmoothed response below 200Hz. Above 200Hz it matches the smoothing set under "graph controls".
Everybody watch out for the next REW beta (b22). It fixes the poor results with XP2040 and has a fix for another EQ matching issue.
Markus
post #399 of 413 Old 07-21-2014, 12:53 PM
thos19's Avatar
New user set-up questions
Markus,
I'm a little late to the party, but my I am replacing my Onkyo PRSC885P and just ordered UMC-200.
I watched the setup videos on the Emotiva website and noticed when going through the menu's there was a "Bi-Amp" option which I would like to use.
I don't see any mention of it in the .pdf of the user's manual and was wondering if you were familiar with it. If it is like my Onkyo, I would use the rear surround output jacks in addition to the front output jacks? Where can I find more detail on this?
Also, I use a Monster Power Center for my components. It has a remote “DC In” Control allowing me to automatically turn on the PowerCenter via the Remote “DC Out”. But the connector to the Pre-amp is a normal wall outlet "plug" which would not work with a pre-amp without a place to plug it in (my Onkyo and ohter receivers I have owned had at least one such plug on the back). Where can I learn more about the triggers on the UMC-200 so I know if it is compatible with my Monster Powere Center in some way? I like the flexibility of my amplifiers turning on automatically when I turn on my pre-amp.
Thanks in advance for your help.
Tom
thos19 is offline
post #400 of 413 Old 07-21-2014, 01:30 PM
elphillips's Avatar
thos19, just set up my system this weekend. Ran a trigger cable from the UMC-202 to a Marantz MM7055 amp' and it works fine. I also use a Monster power center, HTS5100MKll, and tried a couple of hookups with it but prefer the trigger connection.
BTW, after running the EmoQ Gen2 I think it is just about worth the price of the unit. No system mix of components I've had over many years has sounded as good as my current setup.
And this in a room that is far from ideal.
My current setup:
Pioneer 60" 140FD Monitor
Emotiva UMC-202
Marantz MM7055 amp
TiVo Roamio Plus DVR
OPPO BDP-105 Blu-ray player
Darbee video enhancer
Monitor Audio Gold speaker system 5.1
2 Velodyne 12" sub woofers
elphillips is offline
post #401 of 413 Old 07-21-2014, 02:00 PM
thos19's Avatar
Thanks elphillips. I'll consider trying it that way.
BTW, I am using a TiVo series 4. Did you need to output the audio via toslink to your UMC-200? I had read about HDMI audio issues in hooking up TiVo's to the UMC-200, and that was mentioned as a work-around.
My setup is older, but works pretty well:
Sony KV46XBR5 LCD TV
NEW: Emotiva UMC-200 processor
Chiro C500 & C300 amps
Tivo Series 4
AppleTV
Playstation 3
Mirage 3si (front), Csi (center), OM-R2 (side surrounds), BPPS-210 (sub)
thos19 is offline
post #402 of 413 Old 07-21-2014, 02:01 PM - Thread Starter
markus767's Avatar
Quoted: 302 Post(s)
Liked: 171
How would you like to use bi-amping?
Markus
post #403 of 413 Old 07-21-2014, 02:12 PM
elphillips's Avatar
thos19, connected TiVo to the UMC-200 with HDMI. Optical will work. You have to go into the menu and pair the optical with the HDMI your using for video.
Just put this together this weekend.
post #404 of 413 Old 07-21-2014, 02:35 PM - Thread Starter
markus767's Avatar
Quoted: 302 Post(s)
Liked: 171
Very bad idea to put speakers in a cabinet as shown in the picture. Horizontal response will vary a lot due to lobing (interference effect between tweeter and woofer). Those speakers are designed for vertical placement.
Markus
post #405 of 413 Old 07-21-2014, 03:33 PM
elphillips's Avatar
Yeah, but it looks cool. With respect to Mr. D'Appolito, I'll consider placing them on top of the cabinet, upright.
post #406 of 413 Old 07-22-2014, 05:59 AM
thos19's Avatar
My front speakers are very large, and with my Onkyo pre-amp (PRSC-885P), Bi-Amping allowed me to have a separate amplifier channel for the tweeter/mid-range and have a separate amplifier channel for the woofer (providing, in my opinion, improved bass and treble performance).
With my Onkyo, the FRONT L/R outputs feed the front speakers’ tweeter terminals. And the SURR BACK L/R outputs feed the front speakers’ woofer terminals.
I saw the term "BI-AMP" on the menu tree in the setup video on the Emotiva website. I was wondering if the UMC-200 had the same Bi-Amp setup.
thos19 is offline
post #407 of 413 Old 07-22-2014, 09:43 AM - Thread Starter
markus767's Avatar
Quoted: 302 Post(s)
Liked: 171
What speaker model is this?
Markus
post #408 of 413 Old 07-22-2014, 10:02 AM
thrillcat's Avatar
Quoted: 21 Post(s)
Liked: 94
The short answer to your question is yes, it will do this very simply. In fact, it sounds like the Onkyo uses the exact same process to allow bi-amping of your speakers. You give up surround back speakers and gain bi-amping.
http://www.manualslib.com/manual/678...page=30#manual
I love my iPhone, but it will never replace my turntable.
The Cinema 1858 Remodel Thread
thrillcat is offline
post #409 of 413 Old 07-22-2014, 10:08 AM
thos19's Avatar
Mirage 3si
thos19 is offline
post #410 of 413 Old 07-22-2014, 10:10 AM
thos19's Avatar
Thanks thrillcat. Not sure how I missed that.
thrillcat likes this.
thos19 is offline
post #411 of 413 Old 07-22-2014, 10:42 AM
thrillcat's Avatar
Quoted: 21 Post(s)
Liked: 94
Sorry it took almost a full 24 hours to get you an answer to a simple question.
post #412 of 413 Old 07-22-2014, 01:06 PM - Thread Starter
markus767's Avatar
Quoted: 302 Post(s)
Liked: 171
Mirage 3si
Not sure how these speakers would benefit from bi-amping, especially from the useless "bi-amp" implementation the UMC-200 offers. I'd use the passive crossover they came with. Soundwise it's more important to get the splice to the subs right.
Markus
post #413 of 413 Old 07-22-2014, 01:14 PM
thos19's Avatar
I bought these when I worked for Tweeter, Etc. in Boston back in 1993. The Mirage rep. we worked with recommended using the bi-amp option when I bought them via re-seller accommodation. I never questioned the suggestion and I've always been pleased with the sound.
thos19 is offline
Emotiva Umc 200 7 1 Home Theater Preamp Surround Processor , Onkyo Tx Nr3008 9 2 Channel Network Home Theater Receiver , Denon Avr 2312ci Receiver
