SACD sound problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-19-2013, 11:26 PM - Thread Starter
PeterPeter6's Avatar
I have a Pioneer VSX-821 that is suppose to play SACDs. I run a Sony DVP-CX 995V that is a CD/DVD/SACD? etc player. I used to run the Sony through a different receiver and was able to get SACD sound out of it.
I don't get any SACD sound out of the Pioneer VSX-821. All the other formats, CD, etc play just fine in the Sony DVP-CX 995V through the Pioneer. What settings to I need to adjust/fix on the Pioneer? How do I get to those?
PeterPeter6 is offline
post #2 of 10 Old 09-20-2013, 12:07 AM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
When playing back SACDs, you should connect the player to the receiver via the analog outputs...
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #3 of 10 Old 09-20-2013, 05:45 AM
eljaycanuck's Avatar
Quoted: 1225 Post(s)
Liked: 1794
+1. Pg. 22 of the owner's manual states that SACD audio is not output via the coaxial/optical digital outputs or the HDMI output.
eljaycanuck is offline
post #4 of 10 Old 09-20-2013, 10:42 AM - Thread Starter
Thanks for the great feedback guys. I'm a bit of the neophyte when it comes to all of this. Could you please give me the specific Outputs and inputs
I need to hook up the Sony player? Thank you so much for your timely and great help.
post #5 of 10 Old 09-20-2013, 10:53 AM
Liked: 1794
I think you're out of luck with your current set-up. The player only outputs SACD audio through its multi-channel analogue outputs, but the AVR doesn't have a set of multi-channel analogue inputs to connect to.
If it's feasible for you to do so, just pick up an inexpensive (new or used) DVD or BD player that handles SACDs and outputs the audio via HDMI.
post #6 of 10 Old 09-20-2013, 11:10 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
How you did you have it connected to your previous receiver?
First here is the manual for your Sony player.
http://www.docs.sony.com/release/DVPCX995V.pdf
Connect a set of stereo analog (red/white) cables from any one of the 3 outputs I circled in blue. Connect that to the CD input on the back of your Pioneer VSX-821. When you want to listen to SACD's turn your Pioneer to the CD input.
Afro GT
afrogt is offline
post #7 of 10 Old 09-20-2013, 11:17 AM
Liked: 1794
Ah, right, two-channel SACDs. I forgot those exist. In my mind, SACD = multi-channel audio.
post #8 of 10 Old 09-20-2013, 09:29 PM - Thread Starter
Everyone, thank you !
Your quick replies are greatly appreciated. I think I understand it now.
My Sony is a bit on the old side, so it doesn't send OUT the SACD multichannel via HDMI, but only via analog (there via multiple cables). But, if I try to use the cables to connect to the Pioneer, it doesn't have the analog ports for this.
The Pioneer only receives the multichannel SACD via HDMI?
Did I get that correct?
Thanks again,
Peter
post #9 of 10 Old 09-20-2013, 09:38 PM
afrogt's Avatar
Liked: 755
So either get a receiver with multichannel analog inputs or a DVD player that outputs SACD via HDMI.
http://www.amazon.com/OPPO-DV-980H-Up-Converting-Universal-Player/dp/B000UIA6YM/ref=sr_1_23?s=electronics&ie=UTF8&qid=1379734767&sr=1-23&keywords=sacd+player
Afro GT
afrogt is offline
post #10 of 10 Old 09-20-2013, 09:51 PM - Thread Starter
Thanks for the link !
Pioneer Vsx 821 K 5 1 Home Theater Receiver Glossy Black
