Classe Room EQ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-20-2013, 07:12 AM - Thread Starter
jmhenrie's Avatar
Hi I just installed a Classe SSP 800 system and am happy so far but Would like to know how to set up the Room EQ. I would like to have someone that knows what they are doing come and do this but being stuck in the Middle of Washington State, probably out of luck.
So what would I need to do the basic room correction myself?
thanks for any help
Mike
jmhenrie is offline
post #2 of 2 Old 09-20-2013, 08:21 AM
Nyal Mellor's Avatar
Quoted: 455 Post(s)
Liked: 334
thanks for any help
Mike
Hi Mike
Take a look at this article: Room and Sub EQ 101: How to use parametric EQ to flatten your bass.
The measurement system used in the article is XTZ's Room Analyzer II Pro
The low frequency control screen - frequency response, time decay measurements as well as a comprehensive EQ generation and simulation work areas:
'Found room modes' for which EQ filters have been auto generated
Manually flattening the frequency response:
Parametic EQ simulation (whereby EQ is simulated inside the XTZ software enabling you to iterate the EQ values in software before transferring to your Classe):
Some acousticians/calibrators (like myself) can also do EQ work remotely. I can control your computer from my office to measure your room, generate EQ filters, etc. You would need to manually input them into your Classe then we would remeasure. I can do a full in depth home theater calibration this way without ever leaving my desk!
wadeh911 likes this.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
Classe Ct Ssp Processor
