Yamaha RX-V3900 users ( HELP! ) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-21-2013, 10:11 AM - Thread Starter
P5000s's Avatar
Hello everyone!
I have bought this audio set-up:
Speakers:
- Cerwin vega CLS 12 front
- Cerwin vega XLS 6 rear + center
Receiver / amp:
- Yamaha RX-V3900 surround receiver (for rear speakers and center)
- Yamaha P5000 Power amplifier (for the cls-12 fronts)
I am struggling to connect the P5000 amp to the receiver. I am getting no signal and no sound.
A diode on the amp lights when it has signal, but this has never lighted.
I’m not sure why.
Im using phono – to – jack plugs on the amp. The cable from receiver to amp is a Ar9on audio phono cable(RCA?).
Is my connection wrong or is my RX-V3900 making problems?
Im quite new to this also so i`ll post some pictures. A picture says more than 1000 words, right? smile.gif
P5000s is offline
post #2 of 7 Old 09-21-2013, 10:28 AM
braveheart123's Avatar
Quoted: 330 Post(s)
Liked: 287
Your YS Processing is switched on. Switch it off if your speakers have built-in crossover in them. Also, you are using mono TRS plug to feed stereo signal. You need stereo TRS adaptor.
You will also have to match the gain structure between two disparate sound equipments. Yamaha P5000 is a pro amp and RX-V3900 is CE. They both have different gain structure. You need to match them with each other.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
post #3 of 7 Old 09-21-2013, 10:50 AM - Thread Starter
P5000s's Avatar
Thanks for the fast answer braveheart!
I will check and see if the Cls-12`s have built-in crossover.
Is this the adaptor you are talking about?
Link: http://www.ebay.com/itm/New-HOSA-GPM-103-1-8-3-5mm-Female-to-1-4-Male-Stereo-TRS-Adaptor-/400537368784?pt=US_Pro_Audio_Parts_Accessories&hash=item5d41e338d0
Different gain structure and match them up. I have never done anything like that. Do you have a recommended site where i can read more about that and how its done, if you dont have time to tell me?rolleyes.gif
P5000s is offline
post #4 of 7 Old 09-21-2013, 11:26 AM
Quoted: 330 Post(s)
Liked: 287
Yeah that's the correct adaptor
yes.WWW.AVSFORUM.COM
post #5 of 7 Old 09-21-2013, 11:30 AM
Quoted: 330 Post(s)
Liked: 287
That reminds me of the first time I went to DC. I was standing outside the pentagon metro station and I was asking people, "where is pentagon?" biggrin.gif
post #6 of 7 Old 09-22-2013, 10:40 AM - Thread Starter
P5000s's Avatar
The front Cerwin Vega CLS-12 speakers i have, have built in crossover. I will switch the YS-processing off.
I will buy the right adaptor tomorrow.
P5000s is offline
post #7 of 7 Old 09-22-2013, 11:37 AM
Quoted: 330 Post(s)
Liked: 287
All you need to know is very comprehensively covered here;
http://www.hometheatershack.com/forums/home-theater-receivers-processors-amps/35677-gain-structure-home-theater-getting-most-pro-audio-equipment-your-system.html
Yamaha Rx V3900bl Receiver , Cerwin Vega Xls 6 6 Inch 2 Way Xls Series Bookshelf Speaker , Cerwin Vega Cls 12 12 3 Way Tower Speakers
