Denon avr1613 receiver new set up with universal remote (missing factory remote) problem. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-22-2013, 02:27 PM - Thread Starter
axbd's Avatar
Just purchased a Denon AVR-1613 Receiver (Open Box from Best Buy without factory remote). Also purchased a Logitech Harmony 650 Universal Remote. I tried to do the Denon set up with the universal remote but not seeing the on-screen menus as the Owners manual states. I'm not sure how to start this set up. I have a JVC HD-56 FN97 TV that has a HDMI connection and use a Dish Hopper to receive TV. The owners manual for the Denon set up seems straight forward using the factory remote but this was missing with my open box purchase ( I got a great price). I'm not sure how to use the Universal Remote to set up my new Denon. Any help would be greatly appreciated.
axbd is offline
post #2 of 4 Old 09-22-2013, 06:10 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Did they manage to include the calibration microphone or is that missing too? As soon as you plug in the mic the on screen display and Audyssey setup menu should come on.
Since you have no idea on the condition of the receiver before you got it you should probably do a processor reset.
I use Harmony remotes with 2 of my Denon receivers and I can run all the setup menus from it. You should be able to do the same thing with your 650 if you programmed it correctly.
Afro GT
afrogt is offline
post #3 of 4 Old 09-22-2013, 06:31 PM
vzphoneman's Avatar
Quoted: 82 Post(s)
Liked: 78
check this link;
http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=Denon+AVR-1613&uuid=13798961225540
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is online now
post #4 of 4 Old 09-22-2013, 06:33 PM
afrogt's Avatar
Liked: 755
$30 is pretty cheap for a new remote.
You could also call Denon and say you didn't receive a remote when you purchased the 1613. Maybe they'll send you a new one.
Afro GT
afrogt is offline
Denon Avr 1613 Receiver , Logitech Harmony 650 Universal Remote 915 000114x
