Split HDMI into HDMI + Optical - AVS Forum
post #1 of 5 Old 09-23-2013, 12:39 AM - Thread Starter
CaffeRNooB's Avatar
Hello all. Firstly, sorry if this is not the correct place, probably a few boards this thread would be applicable to.
Anyway, I'm looking for the most simple device to split a HDMI signal into a HDMI and optical signal.
Got the new XBOX 360 E, which has had the optical output dropped from it (I know, right...). So in order to connect it to my PC monitor (XL2420T) and PC speakers (Z-5500), without resorting to stereo, I need something to split the signal.
I don't need multiple inputs or switching capabilities, just something simple.
Ideally, this thing from Turtle Beach is what I want, but it's not out yet, and I don't really feel like waiting for sometime between now and the end of "Fall" for it to release.
Any help and ideas would be much appreciated.
CaffeRNooB is offline
post #2 of 5 Old 09-23-2013, 04:14 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 394 Post(s)
Liked: 1339
http://www.monoprice.com/products/product.asp?seq=1&format=2&p_id=5557&CAWELAID=1329451830&catargetid=320013720000010715&cadevice=c&cagpspn=pla&gclid=CM2Dm--x4bkCFUdo7AodMFYAcw
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #3 of 5 Old 09-23-2013, 05:41 AM - Thread Starter
CaffeRNooB's Avatar
post #4 of 5 Old 09-23-2013, 05:59 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 394 Post(s)
Liked: 1339
Depends on your needs as they would both accomplish the goal you're after ... ie. HDMI ---> optical
Item 1 also features a coax digital and 3.5 mm output
Item 2 also features analog R/L outputs
The R/L outputs on item 2 would be a nice feature if you want to pass the audio to Zone 2, not to mention it is currently priced less than item #1. smile.gif
post #5 of 5 Old 09-23-2013, 06:14 AM - Thread Starter
CaffeRNooB's Avatar
User Tag List
