Comtemplating DAC upgrade - Audioengine D1 to DacMagic Plus - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-24-2013, 12:40 PM - Thread Starter
Scottes's Avatar
Quoted: 41 Post(s)
My current setup is the following:
PC
Audioengine D1 DAC (via USB)
NAD C 326BEE Amp
DynAudio Excite X12 Speakers
Martin Logan Dynamo 500 Subwoofer
I am contemplating upgrading the DAC to the Cambridge Audio DacMagic Plus, and was wondering if it was a worthwhile upgrade.
That is, is there enough of a difference between the D1 and the DacMagic to make a difference in what I hear? I certainly noticed a difference when I added the D1 DAC, but it was not some awe-inspiring difference. It was worth $170, for sure, but will the DM+ be worth another $600? Should I wait a bit - which could be a long time from now - and buy a better $1000 DAC?
Yes, I know that I could return the DM, but I know myself fairly well and would almost certainly not return it once I had it in my hands.
Yes, I understand this is very subjective. I just don't have that try-and-return mentality or willpower, so I have to ask. And I understand what a DAC does, but not what makes two DACs different, or why.
Any comments appreciated.
Scottes is offline
post #2 of 4 Old 09-24-2013, 12:51 PM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
The answer is no, the new DAC won't sound any different than the old one in a bias controlled listening comparison. There will be differences in specifications and cosmetics but not in sound quality. In a subjective, sighted comparison, it may well sound different. Dacs are Dacs for the past 15 years or so. Remember, audiophilia is a journey with no destination.
FMW is offline
post #3 of 4 Old 09-25-2013, 12:17 PM - Thread Starter
Scottes's Avatar
Quoted: 41 Post(s)
OK thanks. I did some more research about DAC comparisons in general, rather then specific ones, and it seems like many/most agree with your statements.
I think I'll spend the $600 on room acoustics...
Scottes is offline
post #4 of 4 Old 09-25-2013, 12:26 PM
FMW
FMW's Avatar
Liked: 1681
That makes a bunch of sense to me. Take care.
FMW is offline
Audioengine , Dynaudio , Martinlogan Dynamo 500 Subwoofer Dyn500d , Nad
