What to select, "small" or 'large" speakers when connecting Anthem MRX to a subwoofer? - AVS Forum | Home Theater Discussions And Reviews
Old 09-24-2013, 03:38 PM - Thread Starter
hamptons's Avatar
Quoted: 24 Post(s)
I got my Anthem MRX 700 installed by a pro when setting up the ARC software 2 years ago. Upon checking the settings, I recently noticed that the selection for the floor standing speakers was set to "large" speakers even when the receiver was hooked up to a subwoofer. Shouldn't it set to "small" speakers when connected to a sub? If so, what shall I do to set the speaker selection to "small" instead of "large"? Thanks.
hamptons is offline
Old 09-24-2013, 03:42 PM
jrhooper1963's Avatar
Quoted: 63 Post(s)
Liked: 36
If it were Audyssey, I would tell you to switch them to small for sure. However, I am not familiar with Anthem Room Correction.
jrhooper1963 is offline
Old 09-25-2013, 06:06 AM
r0n1n's Avatar
You should be able to manually set it to small or large, check with the Anthem guys from the other thread
Paradigm Studio 10 v5 | Paradigm CC 490 v5 | Mirage Prestige Nanosat | PSA XS30 | Anthem MRX 310
r0n1n is offline
Anthem Mrx500
