Denon x4000 or Onkyo TXNR929 or Pre-Pro - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #61 of 69 Old 10-02-2013, 03:49 PM - Thread Starter
moodyda's Avatar
Originally Posted by thewirenut View Post
Just get the Denon X4000 and use it with your B&K. No HDMI issues and a better warranty than Onkyo
But wouldn't the Onkyo best it on amplification if down the road I did go to a larger set-up 7.1 or 9.1 and it can control both zones now:rolleyes:
moodyda is offline
post #62 of 69 Old 10-04-2013, 08:39 AM
audio4life's Avatar
Liked: 300
I'm in much the same boat as I compare the Onkyo 929 and the Denon x4000.  I currently have an Onkyo 876 and there are a couple of items about it I never liked.  When switching from SD programming to HD, there would be about an 8 second delay as the HDMI handshake occurred.  Also, the 12V trigger to turn on an external amp was hardwired to do zone 2, not the main zone.
I've noticed that the 929 triggers are again zone 2/3 and it has no switched power outlet to employ a walwart to send a 12V signal to my amp.  So that's a strike against it.  It also appears to have no Audyssey LFC as the X4000 does.  So it's kind of off the table for me.  I'm now wondering if the Denon has that 8 second delay when switching sources.  It seems to me it wouldn't because as I recall, they dealt with that several years ago.  I'd like to eventually go to 9.1 and assume that with the Denon you could assign 2 internal amp channels to front wides, etc.
Any help would be appreciated.
audio4life is offline
post #63 of 69 Old 10-04-2013, 09:05 AM
peterfram's Avatar
Quoted: 135 Post(s)
Liked: 99
The X4000 switches between formats much more quickly and quietly than my old Onkyo HT-RC370. I don't know how long it takes because I no longer even notice it when it happens. The Onkyo used to click loudly and delay when changing channels and audio formats on my Dish Network DVR for example.
peterfram is offline
post #64 of 69 Old 10-04-2013, 10:36 AM
Sean Spamilton's Avatar
Quoted: 348 Post(s)
Liked: 407
You could assign the internal amps to power the front wides / heights ( I believe ) but would still need an external amp to power the two speakers ( fronts ostensibly ) that you are re-assigning. The X-4000 has 7 channels of amplification, with pre-outs for 9 ... so for instance I've got the X-4000 running the typical 7 channel layout, LCR, sides and rears, and am using a two channel amp to power my heights from the height pre-outs.
Sean Spamilton is online now
post #65 of 69 Old 10-04-2013, 01:01 PM
audio4life's Avatar
Liked: 300
It sounds like the Denon is the best option for me then.  I should have mentioned I have a 7 channel amp, so I'd only need to employ 2 of the avr's amp channels for 9.1
post #66 of 69 Old 10-07-2013, 12:07 PM
Patrick Collins's Avatar
Quoted: 47 Post(s)
Liked: 44
After I installed the 929 my I removed my 7 ch. amp without any reluctance.
I understand the apprehension with Onkyo with their heat problems. I'll admit they convinced me they solved the problems but still I had to have a real world comparison. So the 929 replaced my big amp and my Integra DTC 9.8 in my HT. The 9.8 is now in my garage system (I never thought I would see a 9.8 in anyone's garage) with better ventilation. But while the 9.8 has no video connected and the 929 does, the 929 with it's 9 internal amps is running 22 degrees cooler!
The X4000 and the 929 both have full Audyssey treatment to the lowest sub frequencies but the x4000 with Sub EQ HD treats two sub outs separately.
Oh and my wides and highs are an audible improvement.
JD Smoothie, the Oops is on me. While on vacation I discovered your return call..Glad I wasn't too harsh.
Patrick
Patrick Collins is offline
post #67 of 69 Old 10-15-2013, 10:41 PM
johnny hotsauce's Avatar
I'm in a similar situation as the OP in regards to the room my HT is in, our living room is 24x15 with vaulted ceilings that are shared with the kitchen / dining room with a 3/4 wall seperating the 2 spaces.
I currently have a Sony STR-DA5300ES that recently died and I'm looking at options to replace it with and my short list so far is the Denon AVR-X4000 and the Onkyo TX-NR929. I was at our local BB tonight playing with the X4000 and I must say I was pretty impressed with the unit and the Magnolia sales person quoted me $999 (new, not open box), down from the $1299 they have it listed for and I was half tempted to jump on it but I'm still drawn to check out a TX-NR929 before I pull the trigger on either. I know they have similar specs and it seems most tend to lean towards the Denon from what I've been reading so at this point I'm starting to go cross eyed reading up on both of these units, LOL.
Due to the layout of our living room and the vaulted ceilings, my biggest concern is dialouge from the CC, I've always had a probem with my fronts over powering the CC as I sit about 14' from the CC, I originally thought it was the CC itself so I replaced 3 of them (current one is a massive Definitive Tech) until I realized the AVR was the primary culprit, current Sony and previous Onkyo TX-DS676. I hear Audessy XT32 should help correct this issue which is one of the reasons I narrowed the list down to these 2 options and now I'm just torn on which to go with and what the better value is and whether I should take $999 or wait to see what the holiday sales will bring...?
johnny hotsauce is online now
post #68 of 69 Old 10-15-2013, 10:50 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Originally Posted by jdsmoothie View Post
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #69 of 69 Old 10-15-2013, 10:57 PM
Just looking to get the best value of the 2 and the one that most fits my needs biggrin.gif
Denon Avr X4000 7 2 Channel Home Theater Receiver , Onkyo Tx Nr929 9 2 Channel Network A V Receiver , Marantz Av7701 Audio Video Preamp Processor , Pioneer Sc25 Sc 25 Sc 25 Elite 7 1 Channel Digital Home Theater Thx Receiver , Onkyo Ht Rc370 7 2 Channel Thx Certified Network Audio Video Receiver Black
