Onkyo - X1 ugh!!! - AVS Forum | Home Theater Discussions And Reviews
Old 09-25-2013, 07:40 AM - Thread Starter
micaaronfl's Avatar
Hi All,
Well i decided to upgrade my comcast to the X1 box. now my onkyo receiver will change the volume level and turn on when i hit all on the comcast remote but does not turn off when i hit all power on the remote.
i tried a bunch of different codes and have been googling for days.
calling comcast will be a waste so i decided to check here first.
micaaronfl is offline
Old 09-25-2013, 08:33 AM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
try using the "ON" code. I found out for my setup (not the same) that Onkyo appears to use a "power toggle like" mode as opposed to discreet ON OFF codes and also NOT the published "power toggle" code either.
oops... I misread your original post as being you used to "All on" and "All off". As I have found, they (onkyo) appear to publish one thing but implement something different in some receivers. In my case, I had problems with a onkyo 919.
budwich is offline
Old 09-25-2013, 12:28 PM - Thread Starter
micaaronfl's Avatar
thanks for the response, do yuo have any idea where i would find the on code?
Old 09-26-2013, 06:19 AM - Thread Starter
micaaronfl's Avatar
bump
Onkyo
