AVR-3313CI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-27-2013, 08:53 AM - Thread Starter
beauty67's Avatar
I just connected a Definitive Technologies ProCinema 1000 to my AVR-3313CI and for some reason I am not getting any base when playing iPod using USB in front of receiver. It is working fine when watching movies through HDMI 1.
beauty67 is offline
post #2 of 3 Old 09-27-2013, 08:59 AM
braveheart123's Avatar
Quoted: 330 Post(s)
Liked: 287
How did you set up your sub in avr? It should be set as "LFE" with speakers set to small. Also, bypass the crossover on the sub by dialling it all the way to max.
Also check where you have your crossover set in avr. If it is low, raise it to 80Hz and above.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is online now
post #3 of 3 Old 09-27-2013, 09:26 AM
Kini62's Avatar
Quoted: 1692 Post(s)
Liked: 1507
Check the sound format for the USB input. It may be set to direct or stereo or some other setting that doesn't use the sub.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Denon Avr 3313ci Receiver
