Hey pro amp crowd.... - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 01-22-2014, 11:49 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
Originally Posted by Thundersnow View Post
Originally Posted by lovinthehd View Post
Plug your pre-amp/receiver/tv etc as master device and a smart power strip can do the auto on/off for you....http://www.amazon.com/gp/product/B0006PUDQK/ref=oh_details_o05_s00_i01?ie=UTF8&psc=1
That looks like a great option. Although it only is rated for 15 amps I wonder if this would pose a problem when plugging in a 1500 watt amp plus the other on/off source.
Anyone use one of these smart strips to power on/off their pro amp?
I use one for two XLS1500s (one runs L/R, the other C channels). While I haven't tried to melt my speakers, I doubt I'd ever pull that much amperage unless I started testing sine waves or something. Check out the specs from Crown http://www.crownaudio.com/media/wysiwyg//XLS/XLSDrivecore_powerdraw_thermal_keh.pdf
lovinthehd is offline
post #32 of 37 Old 01-24-2014, 08:15 PM
blazar's Avatar
Quoted: 754 Post(s)
Liked: 539
I had 6 crowns coming on at once blowing my circuit breaker so i had to buy a 12v triggered furman power sequencer to turn on the amps.
The 12volt trigger from my receiver only turns on the extra amps when i select a movie input.
Blazar!
blazar is offline
post #33 of 37 Old 01-24-2014, 08:26 PM
M Code's Avatar
Quoted: 815 Post(s)
Liked: 499
The problem is the total current draw when powering everything up simultaneously.....
We have used this power strip in certain pro audio applications with good results...
Basically it has a Power ON & OFF sequence with an adjustable delay up to 15 seconds between each AC outlet...
http://www.notreble.com/buzz/2013/07/25/rockn-stompn-introduces-rs-4-sequential-power-supply/
Just my $0.05.... 👍😉
M Code is offline
post #34 of 37 Old 01-24-2014, 09:25 PM
lovinthehd's Avatar
Liked: 4783
How much power does an amp need at start up? I actually had a sub plate amp working off the same strip as the two XLS1500s and no issues except a bit of noise at shutdown....
post #35 of 37 Old 01-24-2014, 09:56 PM
M Code's Avatar
Quoted: 815 Post(s)
Liked: 499
Depends upon the amplifier brand/design..
A typical power amp will draw significant current just when powering up...
Kinda like your car's starter cranks over when everything is cold..
Some amplifiers use a soft start circuit so minimum current is slowly drawn @ power ON.
And the voltage on that circuit will likely sag just during power ON..
If the house has older wiring then his AC circuit may simply be less robust...
M Code is offline
post #36 of 37 Old 01-24-2014, 10:20 PM
lovinthehd's Avatar
Liked: 4783
Thanks. I think all three of mine have some sort of soft start or at least a delay of sorts but no issues so don't think I'll worry about it.
post #37 of 37 Old 01-25-2014, 09:17 PM
Swolephile's Avatar
Quoted: 896 Post(s)
Liked: 356
Originally Posted by Tstan7777 View Post
Well unfortunately the inuke is out because of extra noisy fan and no binding posts. Still leaning crown(xls1500). The yamaha is still on my mind as well as qsc(same wattage for less money). Still got another day.
You could have used a speakon to banana plug cable. They sell on ebay for low prices:
http://m.ebay.com/itm/131025486142?nav=SEARCH&sbk=1
Swolephile is offline
Crown Xls 1500 Power Amplifier 2 Channel 525w 4 Ohms Per Ch , Gx3 By Qsc Audio , Crown Xls1000 Power Amplifier , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Behringer Nu1000dsp Inuke Power Amplifier
