Help on Wireless Set up for new Denon AVR-4520CI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-29-2013, 10:42 PM - Thread Starter
mjb159700's Avatar
I just picked up a new receiver...  thought it was wireless, but it is not.  Does anyone know a good wireless adapter or dongle that is current to buy.  My router is way across the house from the receiver so wired is not an option.  Thanks.
mjb159700 is offline
post #2 of 6 Old 09-29-2013, 10:56 PM
SledgeHammer's Avatar
Quoted: 1008 Post(s)
Liked: 317
You can buy a 4 port wireless bridge. That way you can have 4 ports at your entertainment center.
SledgeHammer is online now
post #3 of 6 Old 09-29-2013, 11:01 PM - Thread Starter
mjb159700's Avatar
Can you provide a link to one that would work.  I"m a bit of a rookie with AVRs.  Are they pretty easy to set up?
post #4 of 6 Old 09-30-2013, 12:06 AM
Liked: 317
What kind of router do you have? Wireless-N I assume? If so, something like:
http://www.amazon.com/gp/offer-listing/B004FMI3DA/ref=sr_1_1_olp?ie=UTF8&qid=1380521075&sr=8-1&keywords=4+port+wireless+n+bridge&condition=new
would work for $42. They are easy to set up. Just plug it into your router (wired) and browse http to the setup page and point it to your wireless network and enter the password. Done. Take it to the TV area.
post #5 of 6 Old 10-09-2013, 03:23 PM - Thread Starter
mjb159700's Avatar
One more question. I have an amp upstairs that controls all speakers on that floor. There is one wire containing 4 wires that run into the amp. Where do I plug those wires in on the receiver. It is an A/B amp that gives options to turn on/off certain rooms. But I only see zones on the new receiver.
post #6 of 6 Old 10-11-2013, 07:51 AM - Thread Starter
mjb159700's Avatar
Denon Avr 4520ci Receiver
