Powering Klipsch RB-81 II ... Denon 3313CI enough? - AVS Forum | Home Theater Discussions And Reviews
Old 09-30-2013, 07:44 AM - Thread Starter
msbruno's Avatar
Powering Klipsch RB-81 II ... Denon 3313CI enough or should I be looking at an external amp sub $400ish?
Pairing the RB-81's with the SVS SB-13 Ultimate and would like to have the RB-81's keep up at higher listening levels.
I understand that the 3313CI's rated at 135WPC and the Behringer A500/Emotive/Crown is rated similarity (sub $400), but an AVR's power will be different that an amp's power rating, but will there be enough of a difference to hear a difference? I would prefer not to spend more than $400 on an external amplifer.
msbruno is offline
Old 09-30-2013, 08:08 AM
eljaycanuck's Avatar
Quoted: 1246 Post(s)
Liked: 1826
Klipsch speakers tend to be very efficient. Run your system using only your AVR. If you find that the speakers are playing cleanly and keeping up with the SB13-Ultra (not Ultimate) at louder volumes, you don't need an external amp.
eljaycanuck is offline
Denon Avr 3313ci Receiver , Klipsch Rb 81 Ii Reference Series Two Way Bookshelf Speaker Cherry Each
