Dolby Digital Plus and Netflix on Various AVRs - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
Old 02-05-2016, 03:56 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Originally Posted by donstevano View Post
I don't believe so. I have successfully streamed DD+ audio into my receiver from various devices over HDMI. It's only the TV that seems to convert the audio..
HDMI supports DD+. The S/PDIF protocol used with optical and ARC does not.
Sent from my SM-G920V using Tapatalk
BIslander is online now
Old 02-05-2016, 04:43 AM
Quoted: 14 Post(s)
Liked: 1
That's interesting, didn't know that.
donstevano is offline
Old 02-05-2016, 04:45 AM
Quoted: 14 Post(s)
Liked: 1
Originally Posted by peter-d-w View Post
I'm using a JU6800 and have no problems with Netflix 5.1 audio. Is the firmware on your H6400 up to date?
Yes it's up to date. Maybe they fixed it in the JU generation..
Old 02-05-2016, 05:12 AM
shoeboo's Avatar
Quoted: 48 Post(s)
Liked: 48
That used to be the case, but isn't true anymore. Roku 4 can output DD+ over optical and at least newer Denons support it Sample post in Roku 4 Thread
I am not sure if any TVs support DD+over ARC.
reallynotnick likes this.
shoeboo is online now
Old 02-05-2016, 05:22 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Sorry, but I do not believe that the poster is correct. It's a limitation of S/PDIF and I have never seen anything to indicate there have been any changes in that protocol. I've spent some time looking for such information. Dolby's own DD+ Technical paper says the codec requires HDMI.
Old 02-05-2016, 05:43 AM
shoeboo's Avatar
Quoted: 48 Post(s)
Liked: 48
Apparently IEC 61937-3 defined transmission of DD+ over S/PDIF around the time of HD-DVD.
I don't have the Roku 4, but have seen issues about this pop up in a few threads. If you look at specs of Roku 4 it says it passes through dd+ over HDMI and optical. link
And thread about it on Roku forum
Old 02-05-2016, 06:11 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Thanks. I will check out that S/PDIF definition when I can. From time to time people post that they are getting Plus over optical. But such posts are quite rare. Assuming S/PDIF support, it would still require transmitting and receiving equipment with that capability. In the case of the poster linked above with a Denon 3312ci, the troubleshooting section of the Denon manual says to make an HDMI connection to get sound with dts-MA, TrueHD, and Dolby Digital Plus.
Old 02-05-2016, 06:19 AM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
HDMI supports DD+ ARC (not the same as HDMI audio) does not. Audio stream FROM the TV is ARC.
sjm817 is offline
Old 02-05-2016, 06:20 AM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
S/PDIF does not support DD+ or any advanced codec.
sjm817 is offline
Old 02-05-2016, 06:27 AM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
Not sure why Roku and others cant seem to make this happen. Its part of the standard
http://www.dolby.com/us/en/technolog...data-sheet.pdf
Dolby Digital Plus ensures
compatibility with the millions
of Dolby Digital equipped receivers
and home theater systems currently
in use, with even better audio
performance than standarddefinition
DVD. Dolby Digital Plus
soundtracks are easily converted
to a 640 kbps Dolby Digital signal
without decoding and reencoding,
for output via S/PDIF. The 640 kbps
bit rate, higher than the 448 kbps
used on DVDs, is fully compatible
with all existing Dolby Digital
decoding products such as A/V
receivers and can provide higherthan-DVD
quality from Dolby Digital
Plus soundtracks
sjm817 is offline
shoeboo's Avatar
Quoted: 48 Post(s)
Liked: 48
Groundhog day was a few days ago link
Old 02-05-2016, 06:48 AM
sjm817's Avatar
Quoted: 243 Post(s)
Liked: 83
Looked (briefly) at the link. I'm not convinced either. DD+ over optical is not part of the Dolby spec. Roku may be doing some sort of trick, or just confusion as there seems to be more people on that thread complaining than anything else. The correct way is to convert DD+ to DD over optical or ARC.
sjm817 is offline
Old 02-05-2016, 08:25 AM
DLCPhoto's Avatar
Quoted: 812 Post(s)
Liked: 225
Originally Posted by DLCPhoto View Post
I am in the midst of an upgrade to my original audio-only system, and will be going to the Marantz AV7702 (not Mk II).
I will be going with a Projector for the video, so the Roku and Chromecast will be plugged directly into the Marantz and then on to the rest of my audio system.
I'm thinking that this should properly handle DD+ or anything contained in the audio stream, but wouldn't mind verification, since these things don't often work the way one would expect.
Perhaps too basic a question, but I'm still interested in getting a definitive answer here.
JVC RS400, Marantz SR7010, Screen Innovations 160" 2.35:1 Screen
Front L/R: Duntech Sovereigns, each powered by a bridged Adcom GFA-555; Center JBL LSR-308
Dolby Bed (4): Wharfedale Diamond II's, Atmos (4): Ascend Acoustics CBM-170 SE
Subwoofer: DIY 8' sub with 4 18" SI Drivers, powered by iNuke 6000
DLC Photography
DLCPhoto is online now
Old 02-05-2016, 08:38 AM
shoeboo's Avatar
Quoted: 48 Post(s)
Liked: 48
You may want to ask this question in the 7702 owners thread, as if they don't have the problem the users are not likely to check here.
In lieu of actual user feedback, I would not expect the 7702 to be effected. This press release (Link) states they released a firmware to update the 7701 (and other effected models), while the 7702 is not mentioned.
DLCPhoto likes this.
Old 02-14-2016, 08:27 PM
Mkilbride's Avatar
Quoted: 57 Post(s)
I'm having this issue on my PC. Glad to see it can be fixed on my PS3 though, will get on that tomorrow. It just started happening lately, really obnoxious.
However, how do I fix it on PC? I can't select audio options on PC for Netflix.
Denin 1712 / 2112, issues on bother when watching Netflix.
Mkilbride is offline
Old 03-05-2016, 12:30 PM
Keenan's Avatar
Quoted: 2307 Post(s)
Liked: 2134
Getting ready to pick up a Pioneer VSX-830-K for my mother and I was wondering if anyone has heard of any DD+ issues with this model?
Keenan is offline
Old 04-17-2016, 11:21 PM
nathan_h's Avatar
Quoted: 1149 Post(s)
Liked: 726
Looks like the IEC wants to charge for the full 61937-3 spec but from reading the contents it covers e-ac3 (DD+) and commenters on th spec say it covers a limited bandwidth version of DD+
Check out my current theater & gear.
Listen to the best movie review podcast, the /filmcast.
Don't suffer through Gamma D on your JVC. Optimize HDR Tone Mapping using Arve's tool & Masciola's test patterns instead (hints.)
nathan_h is offline
Old 04-18-2016, 05:10 AM
shoeboo's Avatar
Quoted: 48 Post(s)
Liked: 48
The new Vizio P series also supports DD+ with Atmos over HDMI ARC. Seems like a real benefit to not converting stream to plain Dolby digital.
On a side note, bought a Denon Heos soundbar for the bedroom and it has distortion from DD+ on netflix. Pretty disappointing a fairly new product from Denon still has this issue.
Old 06-14-2016, 09:12 AM - Thread Starter
totalkonfuzion's Avatar
So you guys are STILL seeing this DD+ distortion issue on new Denon products? Seriously? My original post was in 2013...wow.
totalkonfuzion is offline
Old 06-14-2016, 10:21 AM
viodea's Avatar
I have the same issue with NAD T-753 receiver (around 2005).
It's been rock solid until I watch Netflix with DD+.
I hear crackling noise from different speakers. I can reproduce it everytime. The same speaker at the same time.
The streaming source is connected to receiver via digital coaxial cable (S/PDIF) since NAD T-753 has no HDMI support.
I'm pretty sure it's decoding issue. I'm just not sure which device is the issue.
I was using a Sony Blu-ray player at first. Then I tried 2 other Samsung Blu-ray players. The same issue.
Then I tried XBOX ONE, no issue. I thank it's because XBOX ONE converts the digital output to either DD or DTS. I tried both options. Neither one has issue.
I tried a bit more testing with Samsung player, there was an option to convert the digital out to DD or DTS. So, I tried that. I could see the source switch between DD and DTS from the receiver.
Then I tried to watch Netflix on the same Samsung player with digital output set to DTS. Nope.... the receiver still saw DD. I'm guessing the Netflix app striping the DD from the DD+ stream and output that directly to the digital out by-passing Samsung codec.
I chatted with Netflix support multiple times and got different answers. Nothing really helps.
Seems like the only option that I have is upgrade my receiver.
viodea is offline
Old 09-10-2016, 11:14 PM
minx88's Avatar
Quoted: 27 Post(s)
I just now discovered this on my 2015 Denon 3200. This is frankly unacceptable as I watch a ton of Netflix. I wish I could return the receiver for another one. Not even stereo works with Netflix, constant auto dropping out no matter what settings. In the meantime I'll have to wait for a 4k HDR with Dolby vision streaming device to spend more money on when I shouldn't have to.
minx88 is offline
Old 09-11-2016, 12:43 AM
Quoted: 94 Post(s)
Liked: 44
Um... wow.
Still? Heos is supposed 'new thinking' and they're still not on board with DD+?
dunnersfella is offline
Old 09-11-2016, 12:18 PM - Thread Starter
Originally Posted by dunnersfella View Post
Um... wow.
I'm going to be in the market for a 4k/HDR TV set soon and that means replacing the Denon 591....maybe with something OTHER than an Denon? lol
Old 09-15-2016, 02:44 PM
minx88's Avatar
Quoted: 27 Post(s)
So for anyone visiting this thraed in the future, after using a few HDMI cables with my Denon 3200x that claimed they were HDMI Premium Certified (even from Monoprice), I bought a Club3D HDMI Premium Certified HDMI cable from amazon (https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1) and it appears my issue has been solved. DD+ from HDMI ARC. HOORAH!
EDIT: Spoke too soon. IT was working perfectly.... shut off my Denon and turned it back on. Issue persists.
minx88 is offline
Old 10-21-2016, 02:29 PM
Bamafan35611's Avatar
Quoted: 101 Post(s)
I will never buy a Denon again cause the Netflix DD+ sound issues continue.
Sent from my SAMSUNG-SM-G891A using Tapatalk
Bamafan35611 is offline
Old 10-21-2016, 03:30 PM
afrogt's Avatar
Quoted: 1172 Post(s)
Liked: 843
Just bought a Denon x3300 and Netflix streams DD+ fine from my Roku 3 and Panasonic Blu Ray player. I haven't had problems with the Denon AVR-591, 2809 or 1613 either.
Afro GT
afrogt is offline
Old 10-21-2016, 03:47 PM
Quoted: 101 Post(s)
Well the AVR 591 is what I have and the DD+ from Netflix sounds terrible but the DD+ from vudu sounds great so I don't know
Old 10-21-2016, 03:51 PM
UHD Addict
aaronwt's Avatar
Quoted: 5604 Post(s)
Liked: 3397
It was fine with my Denon 4520. Not with my 3808 though
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Sony HT-NT3
XBL/PSN: WormholeXtreme
aaronwt is offline
Old 10-31-2016, 04:11 PM
Quoted: 101 Post(s)
Any update on the denon and dd plus from Netflix I would like to subscribe back to Netflix
Old 11-01-2016, 07:15 AM
home_theatre_man's Avatar
Quoted: 25 Post(s)
Liked: 29
Using the Samsung UBD-K8500 and Denon AVR-X7200WA running the most recent firmware, I have not experienced any issues with the Netflix Dolby Digital + stream on Arrow, The Flash, and Supergirl. I'll report back if other shows are affected.
Chase Walton
Technical Editor
PMI, Ltd. / MSR, Inc.
Home Theater Design and Calibration Insider
My comments are my own and do not necessarily reflect the opinion of PMI, Ltd. or MSR, Inc.
home_theatre_man is offline
Denon Avr 591 Receiver
