Help me find a good mid-level receiver with these options.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-01-2013, 09:12 AM - Thread Starter
mj79's Avatar
I'm not to picky, but I do want something up to date, as my current pioneer vsx 819h, just isn't cutting it anymore.
I have Polk monitor 60s, cs2 center, and monitor 40s in the rear, so I won't need a ton of power, but would like blue tooth, wifi, 3d, and something that could be compatible with android and iPhone. Although wifi and blue tooth connectivity would take care of most uses for the phone (music, videos etc)
It doesn't have to be the newest technology, so anything 2012 and up would be fine if there were some good deals out there. But as long as it's a good receiver with those options I mentioned, I would be happy..
Budget is under $500. If possible.
Thanks guys.
mj79 is offline
post #2 of 6 Old 10-01-2013, 12:00 PM - Thread Starter
mj79's Avatar
So far the one that seems to be really highly rated is this one. Seems to have all the features and comes in right under $400
http://m.cnet.com/reviews/sony-str-dn840/35734384
mj79 is offline
post #3 of 6 Old 10-02-2013, 10:10 AM - Thread Starter
mj79's Avatar
mj79 is offline
post #4 of 6 Old 10-02-2013, 11:30 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
I'd say the best in your budget is the denon 1912. It has airplay so you'll have to run an ethernet to the avr. But, it's a great avr.
Denon X3100W
Klipsch RB-61 II (Fronts), Klipsch RC-52 II (Center)
Deftech StudioMonitor 350 (surrounds)
Klipsch SW-115 (sub)
LG 50LB5900
TiVo Roamio
jpcamaro70 is offline
post #5 of 6 Old 10-05-2013, 06:52 PM - Thread Starter
mj79's Avatar
Anyone with any insigjt on the sony dn840?
This seems to be a pretty good av, how is the calibration mic? Pretty easy to setup and accurate ?
mj79 is offline
post #6 of 6 Old 10-06-2013, 05:33 AM
Quoted: 75 Post(s)
Liked: 112
I would go with a Denon. I thought I saw somewhere that Best Buy was blowing out the 2113 model which uses the more advanced MultEQ XT. I don't recall if it has wifi built in, but you can always just get a range extender for $25 and plug it into the ethernet port.
rnatalli is offline
Polk Audio Monitor 60 Am6025 A 2 Way Floorstanding Speaker Single Black , Polk Audio Monitor Series Cs2 Center Channel Speaker Single Black , Polk Audio Monitor 40 Am4025 A 2 Way Bookshelf Speakers Pair Black , Denon Avr 1912 Receiver , Sony Str Dn840
