What is my weakest link? What should I upgrade? System enclosed? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-04-2013, 04:08 PM - Thread Starter
stang233's Avatar
I am looking to upgrade only the sound portion of my home theater system and would like some input on what my weakest link is or where I should invest money next. I just finished adding 7 acoustic panels which helped to tighten up the room. The room is 12’ wide by 25’ long and 8’ ceilings. The theater room is setup lengthwise as expected.
My system:
Receiver: Pioneer VSX 1122
Blu Ray: Panasonic BDT220
Subwoofer: JBL PB12
Speakers: JBL North Ridge NSPii series W/ NSP center channel
Cables: All cables are above PAR to high end.
Power Conditioner: Monster NHT 1700
My initial thought is that either my subwoofer or at least my main speakers need to be upgraded? Does anyone know how this center channel ranks? It seems to perform well?
I was thinking of maybe replacing the JBL PB12 with the SVS PB12 @769.00 dollars.
Or what do you all think?
stang233 is offline
post #2 of 7 Old 10-04-2013, 06:34 PM
oztech's Avatar
Liked: 101
First you need to state what you want more bass, bass extension or tighter bass.
More volume.
More midbass.
You need to state what you think is lacking or you will get all kinds of answers.
There are posters that don't like a particular brand so they will tell you to get rid of it without even hearing what increase you are looking for.
I think the SVS will be a better sub than the JBL.
oztech is offline
post #3 of 7 Old 10-04-2013, 09:27 PM - Thread Starter
stang233's Avatar
Thank you for the response. I feel like i am missing mostly the 150-500 hz range. I would like the sound to feel more crisp and tight.
stang233 is offline
post #4 of 7 Old 10-04-2013, 09:50 PM
BossHoggSocal's Avatar
Klipsch
BossHoggSocal is offline
post #5 of 7 Old 10-04-2013, 09:55 PM - Thread Starter
stang233's Avatar
Sub or speakers?
stang233 is offline
post #6 of 7 Old 10-04-2013, 10:15 PM
Speakers if you want crisp sounding Klipsch Reference.
HSU VTF-15 Sub is probably the best bang for the buck for subs.
post #7 of 7 Old 10-05-2013, 12:06 AM
oztech's Avatar
Liked: 101
150 to 500 you need to take the songs that you like and demo some speakers since that is out of the usefull range of subs .
But before you do that have you tried moving your speakers away from the walls and try a slight toe in if you have not already.
Speaker placement will change how a speaker sounds.
oztech is offline
Pioneer Vsx 1122 K , Panasonic 3d Blu Ray Player Dmp Bdt220 , Hsu Vtf 15h Subwoofer
