Marantz SR-5007 Switches to M XPORT - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-05-2013, 06:22 PM - Thread Starter
DJaye's Avatar
The system is as follows:
A samsung tv, a sony blu-ray player, a Marantz 5007, and a universal mx 780 remote.
Every few days or so while watching TV,  the Marantz switches inputs and the Marantz screen reads : M XPORT
There is nothing hooked up to the M XPORT.
Does anyone know why this would be and how to stop it from happening?
DJaye is offline
post #2 of 6 Old 10-06-2013, 10:47 AM
jdsmoothie's Avatar
Quoted: 15332 Post(s)
Liked: 7488
This issue crops up on D&M models from time to time. Try doing a soft reset by unplugging the power cord for 10 minutes. If still no joy, then try going to INPUTS - HIDE SOURCES and change the M-XPORT setting to HIDE. If it shifts to another source after that, then save the config file to a PC (using Web Control feature) and reset the microprocessor.
jdsmoothie is offline
post #3 of 6 Old 10-06-2013, 12:03 PM - Thread Starter
DJaye's Avatar
We tried unplugging it awhile back and no luck.
I thought of hiding the M-XPORT setting right before I joined up here yesterday and it's good to read that you also think that may do the trick.  The system is not at my house so I won't be able to try it until later this week. I never thought of your last suggestion but hopefully hiding the M-XPORT will do. I had thought there may be interference from a neighbors remote or some other source, but after taking the antenna off the Marantz didn't help, I no longer thought that could be the issue.
Thanks so much for your help!!
DJaye is offline
post #4 of 6 Old 10-16-2013, 06:43 PM - Thread Starter
DJaye's Avatar
The MXPORT has been disabled, but the TV still shuts off and it no longer reads MX-PORT, now it just shuts off and the Marantz is blank.
We have not tried your last suggestion yet, but I was wondering if it could be anything else.
Not sure if TV-AUDIO  on the Marantz has been disabled, is it possible that could cause this issue?
DJaye is offline
post #5 of 6 Old 10-16-2013, 07:30 PM
WSZsr's Avatar
Samsungs have a habit of switching the imput on my receiver to the "TV" input even though my cable box was connected to the "CBL" input which was HDMI 3. So I reassigned the HDMI 3 to "TV" and problem was solved.
Onkyo TX-RZ810 Receiver
Polk Audio RTI A3 Bookshelf Speakers
Polk Audio RTI A1 Bookshelf Speakers
Boston Acoustic VR10 Center
Energy ESW-310 Subwoofer
Samsung UN65ES6500 TV
WSZsr is offline
post #6 of 6 Old 10-17-2013, 04:17 PM
jdsmoothie's Avatar
Liked: 7488
Any brand TV that has the HDMI(ARC) feature will do this when you have HDMI-CEC (Anynet+ in the case of the Samsung) enabled.
Marantz Sr5007 Home Theater Av Receiver
