Denon X1000 or Yamaha RX-V475? - AVS Forum | Home Theater Discussions And Reviews
Old 10-07-2013, 06:30 AM - Thread Starter
Newbuyer's Avatar
HI guys,
Looking to buy either the Denon X1000 or the Yamaha RX-V475. Which one do you think is the better option out of the two?
Newbuyer is offline
Old 10-07-2013, 11:38 AM
Selden Ball's Avatar
Quoted: 3091 Post(s)
Liked: 1509
Denon uses Audyssey which equalizes the subwoofer channel. Yamaha's YPAO does not.
Otherwise, they're both fine receivers. You should compare their features to see which has what you want.
SiggUA and Newbuyer like this.
Selden
Selden Ball is offline
Old 10-08-2013, 02:15 AM - Thread Starter
Newbuyer's Avatar
Thanks for your help!
Newbuyer is offline
Old 10-08-2013, 06:53 AM
Liked: 1509
You're very welcome.
Selden
Denon Avr X1000 5 1 Channel Home Theater Receiver , Yamaha Rx V475 5 1 Channel Network Av Receiver
