With a $800 budget for a home theater setup... What do you suggest? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-08-2013, 06:44 PM - Thread Starter
Kunk's Avatar
Hello everyone. So I just purchased a Samsung 55in F7100 series and I will need some audio to go with it. The problem is I'm not sure what kind of room they will be going in because I am moving overseas soon and I don't know what my living conditions will be then, but I do know of course I'll have a house. Either way the TV WILL be in the main living room. Now I know I could wait until I get to my next place, but problem is I am moving to the UK, and in the US... it is cheaper. So with that being said I would like to see what you all recommend. My budget is $800. I don't need a Blu-Ray player and all that jazz I see in combo packs; just a good audio setup. I have a friend willing to sell me a Bose Acoustimass 10 Series III speakers/subwoofer for $350. They only have about 1-2 years of use in them. I know you all hate Bose, but the price at $350 seems like a good deal. I would need to buy a receiver with those if I go that route. The speakers will be used for gaming, moving watching, and music. Sorry for being vague on some of my descriptions, but I figured this is a good introduction start. Thanks and have a good one.
Kunk is offline
post #2 of 7 Old 10-08-2013, 07:30 PM
jdsmoothie's Avatar
Quoted: 12110 Post(s)
Liked: 5511
Also consider you'll need to use a transformer to convert to 230v/50Hz in the UK so you may want to add that into the equation. Below is a good website to consider both transformers and already converted units.
http://www.220-electronics.com/
jdsmoothie is online now
post #3 of 7 Old 10-08-2013, 07:36 PM - Thread Starter
Kunk's Avatar
Very true thank you sir. I have a few people giving me a few transformers and I believe I am giving a couple when I arrive there (through work) so I should be covered there.
Kunk is offline
post #4 of 7 Old 10-08-2013, 07:56 PM
jdsmoothie's Avatar
Liked: 5511
I would suggest the Energy Take Classic 5.1 setup would be a much better use of your funds for speaker audio quality (not to mention save you $50 in the process). smile.gif
http://www.amazon.com/Energy-Classic-Theater-System-Black/dp/B001202C44/ref=sr_1_1?ie=UTF8&qid=1381283675&sr=8-1&keywords=energy+take+classic+5
Also consider the Denon E300 or if you can get last year's 1613 on clearance at a local Best Buy. That would easily put you inside your budget.
post #5 of 7 Old 10-09-2013, 08:58 AM - Thread Starter
Kunk's Avatar
Great. Thank you for that recomenedation? Any others?
Kunk is offline
post #6 of 7 Old 10-10-2013, 01:21 PM
par4's Avatar
I second the Take Classic......... great value and sound. Well built. Actually kind of ridiculous at this price.
par4 is offline
post #7 of 7 Old 10-13-2013, 06:31 PM - Thread Starter
Kunk's Avatar
Thank you all for the response. I decided to try a different setup. I upped my budget a bit. I created a new thread since the title and discussion in this one is not on-line with what I am looking for now. Thank you all for the advice. I am contemplating some of the items you all listed though.
Kunk is offline
Energy 5 1 Take Classic Home Theater System , Denon Avr E300 , Denon Avr 1613 Receiver
