Recommend some Cheap--Yes I said "CHEAP"--RCA Cables for Analog Output? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-09-2013, 09:00 PM - Thread Starter
Tangled Cable's Avatar
Quoted: 115 Post(s)
Liked: 37
I'm going to get an oppo 93 and hook up its 7.1 analog audio out channels to my ancient denon 3802. So I need to buy 8 short RCA cables to connect the two.
Buying the oppo will leave my HT budget at just about zero, so I don't have a lot of money to spend.
Any recommendations please?
Tangled Cable is offline
post #2 of 8 Old 10-09-2013, 09:19 PM
afrogt's Avatar
Quoted: 1333 Post(s)
Liked: 923
4 stereo cables from monoprice.com
1.5ft, $2.10 each when you purchase 4.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021814&p_id=5346&seq=1&format=2
3ft, $2.77 each
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021814&p_id=2869&seq=1&format=2
you can actually pull them apart and use as individual cables if you want.
Tangled Cable likes this.
Afro GT
afrogt is offline
post #3 of 8 Old 10-09-2013, 09:22 PM - Thread Starter
Quoted: 115 Post(s)
Liked: 37
Awesome, afrogt! Will check those out.
post #4 of 8 Old 10-10-2013, 03:47 AM
Quoted: 75 Post(s)
Liked: 112
Another vote for Monoprice.
rnatalli is offline
post #5 of 8 Old 10-10-2013, 09:32 AM
PCMusicGuy's Avatar
I've used this http://www.ramelectronics.net/product.aspx?zpid=3630 with an additional RCA pair (when I moved from 5.1 to 7.1) in the past with good success.
PCMusicGuy is offline
post #6 of 8 Old 10-10-2013, 02:58 PM
JoeHZ's Avatar
if you can´t wait RadioShack had their decent quality AUVIO cables in clearance last month, 4.99 3ft. . Don´t know if they are still in clearance, but are a good cheap option for sure.
JoeHZ is offline
post #7 of 8 Old 10-10-2013, 03:00 PM
Audiophile2k's Avatar
Liked: 46
on ebay you can get them for under $1 each.
Audiophile2k is offline
post #8 of 8 Old 10-10-2013, 04:49 PM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
check out your local "dollar store" (whatever dollar tree, dollar general, etc). Ours have 3 footers for $1.... and if you really want to save that dollar, you can also get a 3 rca cable so just buy three of those.... :-)
budwich is offline
Monoprice
