Banana Plugs - AVS Forum
post #1 of 6 Old 10-11-2013, 02:39 AM - Thread Starter
Russ1's Avatar
Just a quick one hopefully...
I want to run four speakers from one amplifier but I want to make the connection with banana plugs, Can I put two lots of speaker cable into 1 banana plug?  I assume you are limited to how thick the wire is but in principle is it possible / recommended?
Russ1 is offline
post #2 of 6 Old 10-11-2013, 04:47 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 354 Post(s)
Liked: 1318
Yes, basically wiring the speakers in parallel which will reduce the impedance by 1/2 (ie. if 8 ohm speakers, the amp would see a 4 ohm load).
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun, leave message)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #3 of 6 Old 10-11-2013, 07:06 AM
afrogt's Avatar
Quoted: 58 Post(s)
Liked: 351
Make sure your amp can handle 4 ohm loads then.
What amp/receiver do you have?
Afro GT
afrogt is online now
post #4 of 6 Old 10-11-2013, 07:37 AM - Thread Starter
Russ1's Avatar
I have a rotel Ra-15 amp and Kef LS50 speakers.  The additional speakers I want to attach are Kef Q35's
Russ1 is offline
post #5 of 6 Old 10-11-2013, 07:50 AM
afrogt's Avatar
Quoted: 58 Post(s)
Liked: 351
Does that amp have a set of A and B speaker terminals?
Afro GT
post #6 of 6 Old 10-11-2013, 08:16 AM - Thread Starter
Russ1's Avatar
A & B, yes it does
Russ1 is offline
User Tag List
