Denon 2311 dying? Video and sound cutting out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-11-2013, 05:33 PM - Thread Starter
rr14's Avatar
Quoted: 24 Post(s)
Hi everyone. I have a demon 2311 that is cutting out periodically regardless of source. It'll cut out for 4 or 5 seconds, loose sound, loose video and the input indicators disappear . At first I thought it was a bad hdmi cable, but it's happening with multiple sources. ( Xbox , directv). It's happening when the unit is not hot. What gives?
rr14 is offline
post #2 of 3 Old 10-11-2013, 08:58 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 9355 Post(s)
Liked: 4316
Try unplugging the unit for 10 minutes and if still no joy, then reset the microprocessor (p. 84 OM). Otherwise, if purchased from an authorized dealer, the unit has a 3 year warranty so check Denon's website to see if there is an authorized repair shop in your local area.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is online now
post #3 of 3 Old 10-14-2013, 02:41 PM - Thread Starter
rr14's Avatar
Quoted: 24 Post(s)
Cool. I'll give it a try. I bought it from electronics expo which I believe is an authorized dealer.
rr14 is offline
Denon Avr 2311ci Receiver , Denon , Denon Electronics
