Denon AVR 789 No video when playing Blu Ray via hdmi - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-12-2013, 08:18 AM - Thread Starter
aero993's Avatar
I recently rented a few newly released Blu Ray movies. I noticed, that I was getting sound but no picture. I upgrade the firmware in player thinking that was the problem. After the upgrade, I still had no picture. So I purchased a new Samsung player and there is still no pictture. I have reset the unit several times. I tried using a new hdmi cable. One thing that is strange, it plays my directv via hdmi fine. Any ideas what the problem could be?
aero993 is offline
post #2 of 5 Old 10-12-2013, 08:23 AM
budwich's Avatar
Quoted: 62 Post(s)
Liked: 31
well, its sounds like you tried all sort of things at the source end, but you have given little / no details at the sink / display end so guesses are probably only response. What tv are you using? Have you tried resetting it. What resolutions have you tried? Go to the lowest and start from there. Turn off "deep color" options in any source.
budwich is offline
post #3 of 5 Old 10-12-2013, 01:45 PM - Thread Starter
aero993's Avatar
Something interesting, I hooked two different Blu Ray players up to my Samsung tv. Regular dvd played fine Blu Ray had the same problem. Beginning to look like it's the tv with the problem. Tv is a 42inch Samsung.
aero993 is offline
post #4 of 5 Old 10-12-2013, 01:52 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Maybe you have your player set to 1080p/24 output?
Or deep color is on? Try turning both of those off.
How old is your TV? What's the highest resolution?
Afro GT
afrogt is online now
post #5 of 5 Old 10-13-2013, 12:17 PM - Thread Starter
aero993's Avatar
Player had deep color and 1080/24 set turned them off.
Everything works now, thanks
aero993 is offline
Denon Avr 789 630 Watt 7 1 Channel Home Theater Receiver
