speakers almost rdy :) need help on pre amp or receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-12-2013, 10:12 AM - Thread Starter
Lebreeze's Avatar
I need some help deciding whether to get a pre amp or a receiver. My setup will be a 2.0 system for listening to music and watching T.V. I already have a dedicated H.T for movies. My speakers are in the process of being made. They are Salk veracity S.T's in Mexican Zircote. I've already bought a XPA-2 gen 2 to power the ST's. I'm not sure if I should get a pre amp or just a decent receiver. I'm looking to spend around or less than $1300. I've never had a pre amp before so not sure of the adv/dis. I need some expert help and options please.
thanks
Lebreeze is offline
post #2 of 5 Old 10-12-2013, 12:55 PM
smitty8451's Avatar
Quoted: 64 Post(s)
Liked: 87
I would look at the denon dn-500 or find a higher end used Pre amp at audiogon ect. There is a lot of nice vintage Pre pros out there for stereo playback.smile.gif
Yamaha CX-A5000, ATI AT 2007 Amp, ATI AT 2004 Amp, Klipsch La Scala II- Main, RB 61's - Front heights, RC-62 - Center, RS-62's - Surround, RS-52's - Rear Surround, 2 Rythmik DS-1510 DIY Subwoofers each connected with Antimode Dual Core 2, Oppo BDP-95, MMF-7.1, Project Phono Box RS, XBox 360, XBox One, Oppo HA-1, TEAC PD-501HR transport, Atech Fabrication 7000 fanless HTPC and TASCAM DA-3000 SS Recorder, Kramer VS-88A Matrix Switch, Rogue Audio Pharaoh Int amp, Sony HAPZ1-ES
smitty8451 is offline
post #3 of 5 Old 10-13-2013, 04:51 PM - Thread Starter
Lebreeze's Avatar
Lebreeze is offline
post #4 of 5 Old 10-16-2013, 12:17 PM - Thread Starter
Lebreeze's Avatar
Is there any advantage with a pre amp over a receiver. My outputs
will be direct tv and Apple TV only.
Lebreeze is offline
post #5 of 5 Old 10-16-2013, 12:25 PM
M Code's Avatar
Quoted: 794 Post(s)
Liked: 486
Primarily unit $ cost...
Production unit volume for AVRs are significantly higher than those of separate component preamp/controllers...
AVRs hold a 90% market share vs. 10% for separate components..
Just my $0.05...👍😉
M Code is offline
