Yamaha RX-V675 or RX-A730 - AVS Forum | Home Theater Discussions And Reviews
Old 10-13-2013, 08:51 PM - Thread Starter
jfalek's Avatar
After looking around,for an AVR for a 5.1 setup with airplay, network radio and a 2nd zone. I have settled on either RX-V675 or RX-A730. The RX-V675 is $600 and the RX-A730 is $650 from Amazon. They both have exactly the same stats and either would work in my environment. In fact, they are so similar, I can't tell them apart outside of:
  • A730 has 5 feet over 4 feet (does this really matter?)
  • A730 has an aluminum front (does this really matter?)
  • A730 has a programmable +12 V trigger output (not important to me)
  • A730 is the bottom of the 2013 Yamaha Aventage series
  • V675 is the top of the 2013 Yamaha v*75 series
Does anyone know why I should go for the A730 over the V675?
Thank you!
jfalek is offline
Old 10-13-2013, 09:32 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
I think you should save $200 and get last years RX-V673 for $399 from Amazon.
It would work in your environment too!
Afro GT
afrogt is offline
Old 10-13-2013, 10:39 PM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5213
Actually the 77x series is the top of the RX-V models. That being said I would go with either a 773 or 820 since these models have pre amp outputs and multi point ypao(measures up to 8 positions).
http://www.accessories4less.com/make-a-store/item/YAMRXA820BL/YAMAHA-RX-A820-7.2-Channel-Network-AVENTAGE-AV-Receiver/1.html
http://www.accessories4less.com/make-a-store/item/YAMRXV773WABL/YAMAHA-RX-V773WA-7.2-Channel-Network-AV-Receiver-w/Wireless-Adapter/1.html
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
Old 10-19-2013, 06:04 AM - Thread Starter
jfalek's Avatar
This is very helpful and after days of research, I've decided to go the RX-A820 through accessories4less (I had never heard of them previously).
As I was thinking about this, I looked at my old Infinity RS-5 and wondered about replacing them too. I use my system for 80% music and 20% watching movies. Here is what the room looks like:
The stereo in the picture is stereo cabinet with the RS-5's on either side and a HDTV on top. The sub (Power Sound Audio XS15) is new and I am keeping it. Any bookshelf speakers would go in the same location as the RS-5s and would need a stand. I am trying to keep it under $600.
Any recommendations?
jfalek is offline
Old 10-25-2013, 11:53 PM
systemBuilder2's Avatar
I just brought home a Yamaha TSR-6750 from Costco. This receiver is ostensibly an RX-V675 with the wireless 802.11 dongle included. You might want to check this out if you are a Costco member or if you know a Costco member, because these receivers only cost $489 (including 802.11), which is more than $100 cheaper than the street price for an RX-V675.
I am told that YPAO doesn't work very well - no matter what version you acquire, and you will end up manually adjusting the channel sound balance anyway, so I wouldn't take YPAO device or YPAO version into consideration when making my choice.
systemBuilder2 is offline
Yamaha Rx V675 7 2 Channel Network Av Receiver , Yamaha Rx A730 7 2 Channel Network Aventage Home Theater Receiver , Yamaha Rx V673 Receiver , Yamaha Rx V773wa Receiver , Yamaha Rx A820 7 2 Channel Network Aventage Av Receiver
