Recommend me a receiver ~$300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-14-2013, 02:51 PM - Thread Starter
kasperek04's Avatar
Hello all,
I was wondering if you could help point me towards a good receiver for my upcoming home theater system (mostly for movie watching/gaming)
Things I will be hooking up to it:
2.1 setup:
Bookshelves: Pioneer BS22
Sub: BIC America F12
Projector (likely epson 8350)
Gamecube(composite video cable)
I was looking at the Onkyo NR 616 but even with the firmware updates I fear that something will fry internally within three years anyway so I've been looking at other options, also I see that it has Audyssey 2EQ and I'd really like something with at least MultEQ.
Additional features such as pandora, airplay etc don't have too much value to me since I can do the equiv with a roku or the like, I'm mostly looking for sound quality/reliability.
Questions:
Should I care about 4k at all or is it likely I'll have replaced my receiver anyway by the time it is utilized?
If I decide I don't want to upscale the connection on my gamecube, can I just connect the proper cable from the receiver to the projector and have it run at the native resolution instead?
Thanks a ton
kasperek04 is offline
post #2 of 2 Old 10-14-2013, 04:01 PM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
You may want to consider the lower level Denon models 1613 (MultEQ) and 1713 (MultEQ XT) as a refurb from authorized reseller Accessories4Less.
jdsmoothie is offline
Onkyo Tx Nr616 , Pioneer Andrew Jones Designed Bookshelf Loudspeakers Sp Bs22 Lr , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
