No audio from front wides... - AVS Forum | Home Theater Discussions And Reviews
Old 10-16-2013, 12:13 PM - Thread Starter
matrix64015's Avatar
Running X4000 & I am using a Denon AVR 988 as my external amp for 2 sets of speakers. One to run Front Wide, the other to give the X4000 a little more headroom. Set it up like this last month but after sending it to a service shop, cannot figure out exactly how it was all set up before. Here’s what I’ve done…
Ran set of RCA plugs from X4000 pre outs (using Front Wide & Rear Surround jacks) to 988’s Ext In (using Surround L/R & Front A jacks). And then speaker wire from front wides & rear surround goes to the corresponding speaker posts on the 988 (Front A & Surround L/R). Changed settings on 988 to zero all levels (except volume) & run it in Ext In. On the X4000 I changed Amp Assign to 9.1 & chose Front Wide as Main Pre Amps. Even set the Front Wide as on & + 2 on stage. But whenever I run Test Tone there is nothing from the Front Wides. Rear Surrounds are working fine. I tried changing Surround Sound field to ASX (with Wide) & still no go.
What am I missing here? Should I instead be amping the Side Surround on the set up because you cannot ext amp & run both Rear Surround & Front Wide in the 9.1 because you can only ext amp assign one OR the other? Is there something I missed setting up within the 988 menus?
Thanks guys!
matrix64015 is offline
Old 10-16-2013, 03:11 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
jdsmoothie is offline
Denon Avr X4000 7 2 Channel Home Theater Receiver
