Sherwood R-972 DAC and AMP performance with Music - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 10-18-2013, 12:03 PM - Thread Starter
loganross's Avatar
Quoted: 136 Post(s)
Liked: 63
Hello. I recently purchased one to replace a Marantz receiver in a an audio/theater setup (projection plus Celestion 4ohm A series speakers). Trinnov is great and has been discussed enough, so I am not looking to address that here. I would like to get impressions from others who have or have had this unit. Specifically how do you view DAC and AMP performance relative to other high end setups you have experienced. My interest is in music from high quality sources (such as SACD and lossless FLAC). My experience thus far is that the sound is great, but not as warm as the Marantz. Also, sound stage seems slightly less. In effect, I have options: return it (which I don't intend to do), run it as is, or pair it with a separate AMP. It would be great if you could share your experience and/or solutions.
loganross is offline
post #2 of 12 Old 10-18-2013, 09:19 PM
pwiss's Avatar
Originally Posted by loganross View Post
Hello. I recently purchased one to replace a Marantz receiver in a an audio/theater setup (projection plus Celestion 4ohm A series speakers). Trinnov is great and has been discussed enough, so I am not looking to address that here. I would like to get impressions from others who have or have had this unit. Specifically how do you view DAC and AMP performance relative to other high end setups you have experienced. My interest is in music from high quality sources (such as SACD and lossless FLAC). My experience thus far is that the sound is great, but not as warm as the Marantz. Also, sound stage seems slightly less. In effect, I have options: return it (which I don't intend to do), run it as is, or pair it with a separate AMP. It would be great if you could share your experience and/or solutions.[/quote
Have you tried using Cinema eq on? It will roll off the highs to make it sound "warmer". Also you could use Natural which increases bass and lowers the highs. For music I use Flat with Cinema eg off and the +3 db file and it sounds accurate to me.
pwiss is offline
post #3 of 12 Old 10-19-2013, 08:16 AM - Thread Starter
loganross's Avatar
Quoted: 136 Post(s)
Liked: 63
Hi, its not a question of sub bass. It more the lower midrange, where instruments like the bass live. In other words how lifelike are the plucks of the strings...can I feel them and are they not muddy... sound stage has been better since I recalibrated although sometimes it seems as if there is a bias towards the right. Maybe its my ears. 😊 As an FYI, I use audiophile 1 and 3d mapping for music.
post #4 of 12 Old 10-19-2013, 08:39 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 372 Post(s)
Liked: 243
.....although sometimes it seems as if there is a bias towards the right.
What are the azimuth readings for L and R, after cal? They should be within 2 deg max.
RUR is offline
post #5 of 12 Old 10-19-2013, 08:51 AM - Thread Starter
loganross's Avatar
Quoted: 136 Post(s)
Liked: 63
how do I locate those?
post #6 of 12 Old 10-19-2013, 09:20 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 372 Post(s)
Liked: 243
Although I've done multiple calibrations on a friend's 972, I don't have one handy to tell you exactly how to get to the proper screen. Best to post your questions in the lengthy users thread here: http://www.avsforum.com/t/1179978/sherwood-r-972-user-thread
I do own a Trinnov pre-pro, so I'm quite familiar with the ins and outs of Trinnov setup. Getting azimuth set within a couple of degrees is crucial, and may well be the source of your balance issue.
RUR is offline
post #7 of 12 Old 10-19-2013, 10:52 AM - Thread Starter
loganross's Avatar
Quoted: 136 Post(s)
Liked: 63
Hi,
I am familiar with the menus. I just don't know what azimuth is. Do you be leveling in horizontal and vertical leveling?
post #8 of 12 Old 10-19-2013, 11:00 AM - Thread Starter
loganross's Avatar
Quoted: 136 Post(s)
Liked: 63
As a side, I am really interested in hearing AMP and DAC experiences as they as they relate to music......anyone 😃?
post #9 of 12 Old 10-19-2013, 01:34 PM
noah katz's Avatar
Quoted: 884 Post(s)
Liked: 304
Azimuth is the speakers' horizontal angle position; it's shown onscreen during Trinnov calibration process.
Hi,
Noah
noah katz is offline
post #10 of 12 Old 10-19-2013, 06:34 PM - Thread Starter
loganross's Avatar
Quoted: 136 Post(s)
Liked: 63
Got it. I will look it up and reply back.
post #11 of 12 Old 10-19-2013, 06:50 PM - Thread Starter
loganross's Avatar
Quoted: 136 Post(s)
Liked: 63
FL, H=22; V=98; 3.46m
C, H=2; V=99; 3.25m
FR, H= -21; V=99; 3.45m
Ok, there are the current readings.
post #12 of 12 Old 05-22-2014, 05:56 PM
3D Audio Consultant
Curt_Trinnov's Avatar
Quoted: 72 Post(s)
Liked: 118
This could be an interesting thread for comparing notes.  As some have used the 972 as a pre/pro only, bypassing amps- is it better?  Experience relative to on the speaker impedance and efficiency?  That is, one would expect complex speaker loads would benefit from external amps, but what about easy to drive speakers?
 Here's some of the data I found on the audio chain for those of you into the details of such things...
The basic architecture is 2x TI 708 DSPs with a sample rate converter between them.
--1st TI DSP : Dolby, HD formats, PLII, etc > SRC @ 48k > 2nd TI DSP : Trinnov processing at 48k/32 bit floating point  > DAC.
--For analog inputs, ADC is a AKM  "AK5381"  with quoted specs of S/N 106dB for 48khz. Max 96k (probably only used at 48k).  There are 2 ADCs- 4 inputs (cal mic needs 4)  An option for stereo sources only, as the 7.1 analog in by-passes all DSP functions.
--DAC is Cirrus Logic "CS4382" with quoted spec of 24bit conversion, up to 192KHz, 11dB dynamic range, 100dB THD+N
--Expect DAC receives 48k for all playback, except Remastering, which doubles sample rate before DAC.
--After the DAC is the volume, "R2A1521FP" with 8 channels, described as " independent Electronic Volume"
Thoughts?
Cheers-
___________
Curt Hoyt
3D Audio Consultant
Trinnov Audio
USA
Curt_Trinnov is offline
Sherwood Newcastle R 972
