Yamaha CX-A5000 or the Marantz AV8801 Pre/Pro? (Owners please chime in) - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #91 of 125 Old 07-12-2014, 11:50 AM
MagnoliaMOE's Avatar
I have the AV8801 currently and I am not happy with the fact that it truncates frequencies above 48 KHz when audyssey xt32 is engaged. I am considering switching to the CX5000 but need to know if YPAO applies the same truncation above 48 kHz. Any insight would be much appreciated.
MagMo
Elite 70" (PRO70X5FD), Oppo BDP-105, Marantz AV-8801, Marantz MM-7055, PS4, PS3 (Fatty SACD), MartinLogan Theos, MartinLogan Stage, MartinLogan Montage, MartinLogan Descent-i
MagnoliaMOE is offline
post #92 of 125 Old 07-12-2014, 01:18 PM
Kal Rubinson's Avatar
Quoted: 672 Post(s)
Liked: 458
The Yamaha is capable of 96kHz signals with YPAO engaged. OTOH, 48kHz PCM means a maximum audio frequency ~24kHz and 96kHz PCM means a maximum audio frequency ~48kHz. No change in the audible range either way.
MagnoliaMOE likes this.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #93 of 125 Old 07-12-2014, 01:26 PM
Thanks Kal, is that something YOU would care about when deciding between processors?
MagMo
post #94 of 125 Old 07-12-2014, 04:04 PM
avsource1's Avatar
So, does Marantz Audyssey XT32 downsample to 48kHZ and YPAO in Yamaha samples to 96KHZ. If I am playing Blu-ray at contains data 24/96KHZ sampling rate would it play at 96kHZ sampling or would it down sample to 48 KHZ like audyssey XT32. Is it similar to Anthem D2V room correction that samples at 96kHz
Revel Salon 2, Voice 2, Gem2, JL audio F113 subs MC601 and MC207 amps, AV8801, Oppo BD103d, Synergistic CTS cables,, Exasound E20 Dac 2
JVC RS40 projector, Black diamond zero edge 106" screen
avsource1 is offline
post #95 of 125 Old 07-13-2014, 08:37 AM
Quoted: 672 Post(s)
Liked: 458
It is a factor but not a definitive one.
Kal Rubinson
post #96 of 125 Old 07-13-2014, 08:38 AM
Quoted: 672 Post(s)
Liked: 458
It is a factor but not a definitive one. After all, imho, Audyssey XT32 is superior to YPAO in its corrections.
Kal Rubinson
post #97 of 125 Old 07-13-2014, 08:40 AM
Quoted: 672 Post(s)
Liked: 458
Yes.
The CX-A5000 will play it at 24/96 without downsampling.[/quote]
Neither "samples" anything, per se, but both will pass 24/96 using REQ without downsampling.
Kal Rubinson
post #98 of 125 Old 07-13-2014, 04:48 PM
Thank you Sir!
MagMo
post #99 of 125 Old 07-14-2014, 05:35 PM
avsource1's Avatar
Yes.
Neither "samples" anything, per se, but both will pass 24/96 using REQ without downsampling.[/QUOTE]
Thanks that's what I thought. I use omnimic for subwoofer calibration and managed to get pretty flat reading on my 2 JL audio subwoofers and reading some reviews looks like Yamaha would be better option for me which I have read provided better midrange (which seems to be a issue in my room when using XT32 via 8801) and natural highs without truncation. Have tried all options of audyssey xt32 and have not been satisfied both in music and multichannel movies. I have to skip to pure direct to play multichannel DSD which I prefer.
May be eventually try Trinnov as a more expensive option.
post #100 of 125 Old 07-14-2014, 06:39 PM
mmwwmm's Avatar
Quoted: 66 Post(s)
Liked: 37
Anyone have used the YPAO volume that comes with the latest CX-A5000 firmware? If so what do you think about it? Is it as good as the Dynamic EQ or just worst?
By the way I have owned some of the latest Aventage 20XX and 30XX models and i can confirm that in these models YPAO eq the subs down to 31hz with very good results and compared directly with XT32 in my room. Just take note YPAO has problems when eq subs of the "push pull" type (i.e. B&W PV1D). Using YPAO with these subs gives very strange and wrong results (usually boosting heavily the sub frecuencies around the LF crossover point).
Another point to take in consideration it's to use always just single point measurements. I and other users have noticed that the very best and precise holographic surround field and neutral sound only it's achieved using single point measurement.
Hope this helps.
mmwwmm is offline
post #101 of 125 Old 07-14-2014, 07:44 PM
Quoted: 672 Post(s)
Liked: 458
Must be a YPAO thing. Not so with other REQ systems.
Kal Rubinson
post #102 of 125 Old 07-15-2014, 12:55 AM
mmwwmm's Avatar
Quoted: 66 Post(s)
Liked: 37
You are right. I have owned Denon 4520 and with XT32 (unlike the YPAO) the best results are always obtained using eight mic positions readings.
mmwwmm is offline
post #103 of 125 Old 08-03-2014, 07:26 AM
bobpaule's Avatar
Quoted: 22 Post(s)
Liked: 36
Originally Posted by mdrums View Post
....................It's interesting to find that the Integra DHC 80.3 is highly regarded but yet never mention in threads on this forum when people are looking for a AV Processor around the $3000 mark.
The Yamaha CX-A5000, Marantz AV8801 and Integra DHC 80.3 are all in competition with each other.
Good point, also look how many people ignore the superior modular chassis, recessed buttons behind bay door, and pure audio on the internally identical Onkyo PR-SC5509.
But for video and room correction the AV8801 is the winner, especially if the answer to the quote below is YES:
Originally Posted by wse View Post
Are they both truly differential for XLR? I plan to use amplified studio monitors like these:
http://www.focal.com/en/71-sm6
So anyone know, at least fully differentially balanced stereo would be awesome.
I also dislike the disorderly wiring and poorly used real estate inside the Yamaha, HDAM ie tiny analog preamps on each channel would have been nice:
The Marantz would make a terrific companion to my UD9004, would be feeding 7.1 single ended to it, i can bet the tiny HDAM preamps will do a great job with the analog signal.
I always think of Malaysian Yamahas as the Hondas of A/V. My third Yamaha receiver is in the living room for 7 years now and it refuses to misbehave. Lets hope that the AV8801/8802 will become the Audi S4 6MT equivalent
Being a longterm Onkyo/Integra user I have HDMI board cooling worked out to an art by now
bobpaule is offline
post #104 of 125 Old 08-04-2014, 12:44 AM
audiostar88's Avatar
ops someone had already answered this sorry
audiostar88 is offline
post #105 of 125 Old 09-13-2014, 06:50 PM
Liked: 2
Little disappointed to see Marantz started "Copying" almost the same specs from Denon models. Really hope M can keep its own blood that made many respect the brand. Yamaha has the potential IMO: it's a big company with other more profitable(?) business lines (instruments, services, etc.), which can support the R&D of its audio products. Very much interested to read comparisons of Marantz AV8802 vs Yamaha CX-A5050(?) in 2015!
jxz2000 is online now
post #106 of 125 Old 04-01-2015, 03:06 AM
batman144144's Avatar
Quoted: 21 Post(s)
Yamaha vs. Marantz
Hi, guys. I'm close to pulling the trigger on one of these units. After having read this thread, and others on other forums, I'm leaning towards the Yamaha. You can get the 8801 for $1999, now that the 8802 is on the market. The CX-5000 still goes for $2499, which is more expensive, but not that big a deal to me. The single most important thing to me is sound quality and musicality. Marantz has a good reputation for being musical, and SR5005 is my current receiver (that I use as a pre-pro with outboard amplification). However, I find the sound is a little dark for me. I want to upgrade and find something sweeter-sounding. I used to own the Yamaha DSP A-1 back in the day, and I seem to recall it having a brighter sound than my Marantz. Do you guys think the CX-5000 is brighter-sounding than the 8801? I also miss the Hall mode processing that Yamaha is so good at...
For reference, my equipment is: Marantz SR5005, Chiro C-500 amp, Polk LSi bookshelf speakers, Infinity sub. Thanks.
batman144144 is offline
post #107 of 125 Old 04-01-2015, 05:31 AM
dwaleke's Avatar
Quoted: 1114 Post(s)
Liked: 515
These units are getting old now. 8801s are going for about $1k used market.
The new Yamaha processor should be out this summer. Not many on the used market.
The Marantz AV7702 is very popular and can be had for less than 1500 new by calling an authorized dealer. It is said to be superior sounding than the 8801 due to upgraded internals.
That being said it's hard to purchase anything that costs more than 1500 right now. Just get the 7702.
dwaleke is online now
post #108 of 125 Old 04-01-2015, 05:45 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5501
We have both products available as well as the newer AV7702. The Marantz units also ship with a free Denon HEOS Link (MSRP $349) which can be used to stream audio to a non-networking AVR or when can stream audio from the AVR to one or more wireless HEOS speakers (sold separately). If you want more specific information or pricing on these products, please contact us; if we don’t have the product in stock, we can usually get it very quickly.
jdsmoothie is offline
post #109 of 125 Old 04-01-2015, 07:11 AM
Quoted: 21 Post(s)
Smile
Thanks for the info. Newer models are not really important to me. I don't care about Dolby Atmos or whatever else is the latest craze. Your comments regarding the 7702 are very interesting, however, I cannot find it for "less than 1500." I see it online for $1999. FYI: I'm willing to bet the new Yamaha will go for much more than $2499, so I probably won't wait for it. Anyway, do you think 7702 sounds better than the CX-5000?
post #110 of 125 Old 04-01-2015, 09:07 AM
dwaleke's Avatar
Liked: 515
Well in this case a newer model (7702) provides superior sonics compared to an older model (8801) regardless of features such as Atmos.
I never compared the 5000 to the 7702. The Yamaha unit is a good sounding unit and I'm a Yamaha fan in general. I prefer the sonics of the 3020 over the 5000 myself. But you can't go wrong with either.
Oh and you have to call an authorized dealer. You can't shop online. Dealers are not allowed to quote lower than msrp in writing. You'll save a lot by calling.
It it were me I would look at the AV7702 since it is highly regarded, good feature set, and good price. And I'm not a Denon fan or an Audyssey fan (you can add on Dirac for modern room correction if needed with a Minidsp device).
Take a look at the Emotiva XMC-1 as well.
audiofan1 and batman144144 like this.
post #111 of 125 Old 04-01-2015, 08:09 PM
Quoted: 21 Post(s)
Thanks for the info. I didn't realize you could save more by calling a dealer than shopping online. However, I think Best Buy would be my only choice in town for audio gear, and I don't even know which brands they carry. I know for sure they don't have a Magnolia department. I did find the CX-5000 new in box on ebay for $2000, which is a lot less than amazon. Also, another member of this forum recommended the 5000 over the 8801, and said that it is on par with the 8802 for SQ. So, I'm leaning away from Marantz at this point. I did look briefly at the XMC-1; I'll take another look. Thanks again.
post #112 of 125 Old 04-02-2015, 05:20 AM
dwaleke's Avatar
Liked: 515
Call one of the authorized dealers on this forum (also posted in this thread). Best buy won't go low enough unless they are clearing out inventory.
AV electronics are not an item I would buy locally at a brick and mortar store. Too much overhead for them to price low.
post #113 of 125 Old 04-02-2015, 05:42 AM
Quoted: 21 Post(s)
Are there any on the west coast?
post #114 of 125 Old 04-02-2015, 05:46 AM
jdsmoothie's Avatar
Liked: 5501
As an authorized Marantz and Yamaha dealer, we can certainly ship to the west coast. Call if interested in pricing.
post #115 of 125 Old 04-02-2015, 10:34 AM
dwaleke's Avatar
Liked: 515
They ship to the entire country. Their location shouldn't matter.
post #116 of 125 Old 04-02-2015, 04:01 PM
Quoted: 21 Post(s)
Well, that all depends on how patient you are for delivery.
post #117 of 125 Old 04-03-2015, 05:46 PM
Quoted: 21 Post(s)
After briefly toying with the idea of getting the 8802, I ordered the CX-5000. This was probably the toughest call I've had to make when choosing between audio gear. Anyway, it does not ship until Monday.
post #118 of 125 Old 04-03-2015, 06:02 PM
turnne1's Avatar
Quoted: 1754 Post(s)
Liked: 410
and when they are clearing out inventory...in my opinion...there is nothing like them
I havent seen another retailer/etailer come anywhere close to them when they are clearing out inventory
I bought a full set of Bowers and Wilkins speakers ta a Chicagoland area Magnolia Home Theater recently and saved at least a couple of thousand over what the best offer a local B&M dealer would offer me
good for you
Hopefully you didnt pay any where near the price you stated above
Both the Marantz 8801 and Yamaha CX-A5000 can be had currently for far less than you posted above
Warren
dwaleke likes this.
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
post #119 of 125 Old 04-03-2015, 07:08 PM
Quoted: 21 Post(s)
Originally Posted by turnne1 View Post
Hopefully you didnt pay any where near the price you stated above. Both the Marantz 8801 and Yamaha CX-A5000 can be had currently for far less than you posted above
Warren
Really? That's interesting because a dealer I spoke to from this forum could only match the price I mentioned --and not even that, really. He would have had to charge me tax as well. I'm not sure about the shipping. While I did not pay for tax or shipping, I also did not just look for the lowest price and then call it a day. It was very important to me to get the manufacturer's warranty as well as an easy return process. I paid a bit extra for that, but I would do it again, of course.
post #120 of 125 Old 04-03-2015, 07:19 PM
turnne1's Avatar
Liked: 410
yes...really
I paid about 30% less than the price you mentioned above for the Yamaha CX-A5000 months ago from a authorized dealer in the PA/MD area...and it was a delivered/no tax price
i had an issue with it and thus returned it...at no charge to me as the store picked up the return shipping
I consequently bought the Marantz 8801, recently, for even less than I paid for the CX-A5000
I could probably dig up the receipt for the CX-A5000 and let you know where I bought it
though I am sure inventory for them is long gone
On another note
At one time the Marantz was significantly more than the yamaha
Now it seems that remaining new ( and used) yamahas are worth more than the Marantz units are
Pity the folks that bought the Marantz 8-12 months ago that paid at least $1000 more than I did...
Warren
turnne1 is offline
Marantz Av8801 , Yamaha Cx A5000bl Aventage 11 2 Channel Av Pre Amplifier
