Which receiver should be in living room and which one for the bedroom - AVS Forum
post #1 of 3 Old 10-19-2013, 11:53 AM - Thread Starter
tj_jokestar's Avatar
Right now I'm using a Denon 4802 as my main but I just got an e300. Just wondering which one will sound overall better. PS the connections are not a factor.
Thanks Trevor
tj_jokestar is offline
post #2 of 3 Old 10-19-2013, 02:32 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 753 Post(s)
Liked: 1418
Wouldn't it be better to just try each out and determine for yourself which you prefer in each setting? The E300 although a much lower model uses Audyssey MultEQ which should provide possibly better audio quality then even your 4802.
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AV Gear
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Atlantic Tech
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #3 of 3 Old 10-19-2013, 02:39 PM - Thread Starter
Yeah I was going to try that but I figured I'd ask the pros first.
Denon Avr 4802r Av Receiver 7 1 Channel , Denon Avr E300
Gear in this thread - 4802r by PriceGrabber.com
