Pioneer receiver overheating: defective or pushing it too hard? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-22-2013, 03:51 PM - Thread Starter
djsprinkle's Avatar
I recently purchased a Pioneer VSX-822-K with four Infinity Primus P163BK bookshelf speakers and a PC351 center. I like to listen to loud music and use the virtual surround settings to send it to all channels. I go as loud as I can without the music sounding distorted which is maybe 75-85% of max volume, assuming the numeric indicator on the receiver is accurate for actual power output. I have all the speakers set to "small" and crossover at 100Hz; using two BIC F12s for bass.
At this volume, depending on the music, I can often only listen for 5-10 minutes before the receiver shuts down in protect mode. The receiver is quite hot to the touch afterwards. It's in a wide open area with plenty of ventilation in all directions and I even experimented with adding a fan, but it doesn't seem to make a difference. All my speakers are 8 Ohms and I have double checked all the wiring is correct, using quality 16 AWG.
All my searching so far seems to indicate that it's pretty rare for receivers to overheat when they're properly ventilated, so maybe this is just a defective unit, but I wonder if I'm perhaps pushing the power output far beyond its intended use. I can send the receiver in for repair/replacement but I'd hate to go through that process and encounter the same problem again. Any suggestions? Does this sound like a defective unit or am I just too demanding?
djsprinkle is offline
post #2 of 8 Old 10-22-2013, 04:32 PM
jontyrees's Avatar
Liked: 38
Sounds defective to me - you should be able to crank it all the way up without it overheating, if the speakers are 8ohm. Especially if you have the speakers x-d over at 100hz
jontyrees is offline
post #3 of 8 Old 10-22-2013, 04:38 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
The Infinity loudspeakers are low on sensitivity, so significant output power is required..
Be sure to provide @ least 3-4" of free-air clearance for the L/R sides and top cover. Also do not stack anything on top of the Pioneer.
Just my $0.05.... 👍😉
M Code is offline
post #4 of 8 Old 10-22-2013, 05:18 PM
jontyrees's Avatar
Liked: 38
The amp still shouldn't shut down though, even if you have to crank it up to maximum volume to compensate for inefficient speakers. It would just be less loud than max volume with more efficient speakers. Either way, the amp should be able to run at full throttle without shutting down, and this one is only running at 75%. I've never tried it, but I THINK these things are designed to be able to run full out - seems pointless having a volume knob that goes up that high otherwise.
One thing that might be a factor - how do you have the channel level set? If you max'd out the gain on every channel in the manual eq options, you might be over driving the amp.
post #5 of 8 Old 10-22-2013, 05:42 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
The AVR has thermal shutdown protection...
If the amplifiers are being pushed hard and there is inadequate free-air circulation it will shut down.....
Just my $0.05... 👍😉
M Code is offline
post #6 of 8 Old 10-22-2013, 05:46 PM
music_to_my_ear's Avatar
Quoted: 185 Post(s)
Liked: 90
I would suggest contacting pioneer and asking them if that is normal. They will definitely be able to tell you if it is defective or not....after all they would know best
And I remember reading infinity primus speakers being low impedence speaker aka 4 ohms...so it could be a contributing factor. They can be hard to drive for such a low model receiver. Try using some old or smaller bookshelf speakers and see if those drive the receiver into meltdown mode
music_to_my_ear is offline
post #7 of 8 Old 10-22-2013, 11:05 PM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
An amp or avr has a max power limit and the position of the volume knob does not tell you if you have reached the limit. It depend on the content of the source. For example, bass heavy source will reach the power max sooner than sources that don't have a lot of bass. Improper ventilation is a major cause of over heating and shut down in units that are not defective.
derrickdj1 is offline
post #8 of 8 Old 10-23-2013, 12:00 AM - Thread Starter
djsprinkle's Avatar
Well thanks everyone. Based on the responses, it sounds like it's most likely defective. I confirmed my speakers are 8 Ohms and tried swapping two of them for smaller, more sensitive speakers, but I still had the over heating issue after 10 minutes or so. The receiver has nothing on top or next to it, so there's plenty of room for ventilation. Even if Pioneer were to say it's not defective, I don't think I want something that overheats so easily so I'm going to try a different model. I'm leaning towards a Denon E300.
Pioneer Vsx 822 K 400w 5 Channel A V Receiver Network Ready Pandora Ipod Iphone Black , Infinity Primus Pc351 Center Speaker , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
