AV Receivers - audio/video passthru - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-23-2013, 12:15 PM - Thread Starter
jperret's Avatar
I am considering getting a AV receiver.
the quest ion I have is if you pug in all out components, Directv, Blu-ray, etc . . into the AV receiver and then plug one HDMI cable from AV receiver to TV can you get sound and picture from from Twith the AV powered off?
jperret is offline
post #2 of 4 Old 10-23-2013, 12:24 PM
eljaycanuck's Avatar
Quoted: 1232 Post(s)
Liked: 1804
If the AVR you buy has that feature, yes. The signal is simply "passed through" the AVR from the source* directly to the TV.
(*Depending on the AVR, it could be a user-selectable default source, or the last source selected before you powered off the AVR, or other.)
Unofficial Denon "guru" batpig provides more detail on this page.
eljaycanuck is offline
post #3 of 4 Old 10-23-2013, 12:36 PM
walterappleby's Avatar
Quoted: 25 Post(s)
Liked: 77
Correct me if I misunderstand but I think what you are asking is if it's possible to watch, and hear, the TV without using the AV receiver and speakers.
It will depend on the receiver and whether it has the ability to pass a signal while it is in standby (power off) mode. I'm using a Pioneer SC-1522 that has this capability. I have my Blu Ray player and cable box connected to the receiver and then the receiver out to the TV. I can use the AV receiver and speakers or I can just use the TV to watch.
Actually, what I do is use one of my AV receiver's HDMI outputs to send signal to my projector and another to send signal to a small TV/monitor. I use the TV, and leave the receiver off, for quick things like checking the weather/news, programming the DVR, checking TV schedules, etc. This saves the lamp on my projector from a quick on/off cycle when I don't need/want to use the big screen.
If you have some flexibility with how you do your cabling you can probably find some other options, (ie. run signal to both TV and receiver, use ARC on the TV, etc). I only addressed your original question where you wanted to connect everything through the receiver.
walterappleby is offline
post #4 of 4 Old 10-23-2013, 01:49 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
As long as the receiver has Standby Pass Through you'll be fine. And all your sources must be HDMI. Standby pass thru doesn't work on Composite or Component video.
Afro GT
afrogt is offline
Pioneer Sc 1522k 9 2 Channel Av Receiver
