Small foot print AV Receiver Needed - AVS Forum | Home Theater Discussions And Reviews
Old 10-24-2013, 02:16 PM - Thread Starter
xjaywalker's Avatar
I am searching for a unit that is no deeper then 12" to fit in my motorhome. I would prefer it to be slim line as well 3-4 inches, but not a deal breaker. I was interested in the Sherwood N-904N and did not care about the VuNow being bad. Just really liked the size, but the manual did nto list Vizio as a supported TV code,.
Anyone with any help would be appreciated. Thanks
xjaywalker is offline
Old 10-24-2013, 07:52 PM
CrispAndClean's Avatar
Check out the H/K AVR 1510, 1610 or 1710. They are just under 12" deep at 11 13/16".
Crisp'N'Clean
CrispAndClean is offline
Old 10-24-2013, 11:06 PM - Thread Starter
xjaywalker's Avatar
Thanks...I will check it out.
Old 10-25-2013, 03:44 AM
Quoted: 73 Post(s)
Liked: 112
Not sure how deep the Marantz slimline receivers are, but they're pretty short in height. Yamaha also has the S600.
rnatalli is offline
Old 10-25-2013, 10:04 AM
pdks's Avatar
Depending on what your needs are, the new high-fidelity but small footprint integrated amps are intriguing. Here's a link to the Teac A-H01:
http://www.teac.com/product/a-h01/
pdks is offline
Sherwood R 904n 700 Watt 7 1 Channel Dual Zone Receiver Black , Harman Kardon Avr 1510 5 1 Channel 75 Watt Networked Audio Video Receiver , Harman Kardon Avr 1710 7 2 Channel 100 Watt Network Connected Audio Video Receiver
