Do HDMI 1.4a capable AV receivers support Ethernet Channel ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-25-2013, 08:31 PM - Thread Starter
hyperspaced's Avatar
Hello,
Title is self explanatory. Do HDMI 1.4a capable AV receivers support Ethernet Channel ?
Does this mean that I hook-up the ethernet cable on my AV receiver and it acts as an Ethernet-over-HDMI network switch (i.e. a standard ethernet switch using HDMI cables) ?
hyperspaced is offline
post #2 of 6 Old 10-25-2013, 08:50 PM
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Originally Posted by hyperspaced View Post
Hello,
Note that Ethernet is an option, but not mandatory for HDMI 1.4 AVRs..
To verify, you need to identify the specific brand/model..
Just my $0.05... 👍😉
M Code is online now
post #3 of 6 Old 10-25-2013, 10:43 PM
balboa dave's Avatar
Quoted: 17 Post(s)
Unless your manual explicitly state your component has Ethernet over HDMI support, no. AND, you'll need cables that support it too.
balboa dave is offline
post #4 of 6 Old 10-25-2013, 10:51 PM
Ross Ridge's Avatar
Liked: 81
No AV receiver supports Ethernet over HDMI. In fact I don't think there is any device on the market that does support it.
Ross Ridge is offline
post #5 of 6 Old 10-26-2013, 08:36 PM - Thread Starter
So, are you saying that current HDMI 1.4a AV receivers don't even let the ethernet channel pass through ?
Okay, let me give an example in order to become more specific:
- I connect all my sources to a current AV receiver through HDMI (e.g. Yamaha RX-V 475). The AV receiver is connected to the TV through HDMI as well.
- Let's suppose that in 6 months from now, a TV capable of Ethernet-over-HDMI is out.
- I hook the ethernet cable to the new TV.
- TV and AV receiver are connected with ethernet-capable HDMI cable.
- QUESTION: Do I get ethernet on the Ethernet-over-HDMI capable connected sources ?
post #6 of 6 Old 10-26-2013, 11:23 PM
Ross Ridge's Avatar
Liked: 81
Your current receiver, like all AV receivers, doesn't support Ethernet over HDMI. If a TV ever comes out that supports Ethernet over HDMI, your receiver won't be able to connect to your home network through such a TV, nor will any device connected to one of your receiver's HDMI inputs.
I don't think it's likely that you'll find any TVs, AV receivers or any other device that supports Ethernet over HDMI in the next six months. Maybe not ever.
hyperspaced likes this.
Yamaha Rx V475 5 1 Channel Network Av Receiver
