Marantz 8801 and amp not communicating - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-26-2013, 11:18 AM - Thread Starter
rsaudarg's Avatar
Just received the 8801. Other components are (1) Panasonic Plasma TV (2) Oppo 95 (3) Parasound CA51 5 channel Amp (4) REL powered subwoofer (5) Monitor Audio Gold Main, Center, and Right and Left Surround Speakers. HDMI cables are connected to TV and OPPO with a. Digital Cable to Comcast Cable Box for now until I get another HDMI cable. Ethernet Cable to PC and 8801 shows on computer as part of network. The OPPO HDMI connection is working since when I switch to BlueRay on the 8801 and TV I can see a CD play, but no sound.
Problems: (a) No sound from speakers. I believe I connected the Amp to the 8801 correctly, but maybe not. The amp worked fine with my previous set up; a McIntosh MX130 and MSD4 (b) The 8801 no longer displays the Set Up or anything when I switch to the HDMI channel connection on the TV, (c) I skipped the Audyssey set up but can no longer get back to set up on the TV. (d) there is a set up button on the remote, which doesn't change the 8801 screen.
I know this is long, but it's been frustrating and befuddling, and feel I must have missed something simple. I have downloaded the manual and looked through it, to no avail.
I appreciate any suggestions and solutions.
rsaudarg is offline
post #2 of 5 Old 10-26-2013, 06:52 PM
chatanika's Avatar
try unplugging the microphone and then plug back in.
chatanika is offline
post #3 of 5 Old 10-26-2013, 06:59 PM
audiofan1's Avatar
Quoted: 1650 Post(s)
Liked: 1666
Did you go through the initial setup wizard when it prompted you to input your connection methods i.e rca or xlr for amp connections? also be sure you're using the preamp outs and not the 7.1 inputs
audiofan1 is offline
post #4 of 5 Old 10-26-2013, 07:37 PM - Thread Starter
rsaudarg's Avatar
When I originally set up it because of the number of my speakers, I naively hooked into the 7.1 lines, which looks like my error. I pulled the cables and unplugged the Marantz and reentered the cables in the pre-outs, but still no sound. Is there a way to start over?
rsaudarg is offline
post #5 of 5 Old 10-27-2013, 08:22 AM - Thread Starter
rsaudarg's Avatar
I'm good. I reset the processor which allowed me to get back into the set up so I could start over and follow instructions more carefully. Thanks for the help.
rsaudarg is offline
Marantz Av8801
